I'm finding the Zeniths to be on the bright side in general. Coming from something like AKG N5005s, the Zeniths seem really bright and take some getting used to. Still on a tip search though and haven't come to any definite conclusions on what is best.
IMR - R1 Thread
- Thread starter AudioJunki3
I've found inears to be the best I've tried so far. They tame them a little without taking much away.I'm finding the Zeniths to be on the bright side in general. Coming from something like AKG N5005s, the Zeniths seem really bright and take some getting used to. Still on a tip search though and haven't come to any definite conclusions on what is best.
Not familiar with "inears". Is that the brand? Google search didn't pull up anything relevant (at least on the first hit page).I've found inears to be the best I've tried so far. They tame them a little without taking much away.
https://www.amazon.co.uk/s/?ie=UTF8...77&hvtargid=aud-615159460541:kwd-301046522833Not familiar with "inears". Is that the brand? Google search didn't pull up anything relevant (at least on the first hit page).
My bad. Actually inairs not inears
Ok, found them. For some reason, foam has never worked for me. Thanks for the suggestion though!https://www.amazon.co.uk/s/?ie=UTF8...77&hvtargid=aud-615159460541:kwd-301046522833
Joining in the tip debate, I'm finding these pretty fit (or more accurately ,seal) dependent. Tried them today with a set of Flare Audio Earfoams and I think I've found my preferred tip for the long haul. Seal is perfect and the cone shaped bore doesn't muffle or damp the sound, so if you have a set, definitely worth a try.
Got my replacement Zenith today (UK) and there does seem to be a noticeable improvement over the old phase-incorrect model, even though I was running then with cables in the correct phase.
Matt just be expectation bias, but planning on running them both through my measurement rig to see if I can spot anything obvious so will report back in due course.
Jasonsdman
- Aug 1, 2011
Been using the new Zenith for a week now. Definitely an improvement over the old Zenith and the R1. It took a little time to open up though. I don't believe it's a phase issue as the old Zenith sounds worse than the R1 no matter what I do. I'm glad Bob sorted it out, whatever it was.
AverageDude
Formerly known as SchiitHead
Thanks for the tip (see what I did there)! Is the Air 3 the most apprepriate model for the Zenith? They seem to be the narrower, whereas I find the Zenith's nozel quite large. I'll follow your suggestion anyway.https://www.amazon.co.uk/s/?ie=UTF8...77&hvtargid=aud-615159460541:kwd-301046522833
I use inairs size 2 in medium. For some reason my link shows size 3 but it's size 2 you needThanks for the tip (see what I did there)! Is the Air 3 the most apprepriate model for the Zenith? They seem to be the narrower, whereas I find the Zenith's nozel quite large. I'll follow your suggestion anyway.
nlowran
So.... I have a set of U12t's inc will be interesting to see the diff
Which flares are you using? I've noticed an Audiophile graded tip and a standard version. The standard seem to look like fairly normal foam tips
The Audiophile version - they have a wide bore that expands out, so leaves the nozzle unblocked. Very nice sound.
Juan Carloss
Hello, what balanced cable with memory will go well with Zenith?
Juan Carloss
[QUOTE = "rocko77, post: 14795349, miembro: 508595"] [ATTACH = full] 2628653 [/ ATTACH] [/ QUOTE]
Hola, ¿qué cable usas? se ve muy bien.
Hello, what cable do you use? looks great.
