Kunlun
- Jan 25, 2010
Actually:
"In a recent conversation with Monster founder Noel Lee, I gleaned some insights into the key differences between the Miles Davis model and the similar but definitely not identical Turbine Pro Copper Editions. Despite the fact that the products share similar technology and overall appearance Noel Lee asserted that they do not sound exactly the same. By design, the Miles Davis Tribute model offers a subtle touch of midrange emphasis (intended, in a very subtle way, to complement classic jazz recording of the late ‘50’s and mid-‘60’s), whereas the Turbine Pro Copper Edition offers a more nearly textbook-flat (or neutral) frequency response curve."
Similar is not the same. I personally believe the MD's and the Coppers do not use the same driver for 2 reasons:
1-The Coppers and MD's obviously have different impedance/sensitivity ratings based on my experience w/ the volume settings on my DAP required to drive each one to the same output level. This could be a cable issue since they both use different cables from apearances until you consider the following.
2-The Copper driver is much quicker than the MD or Gold. I actually think the MD is an optimized and tuned version of the Gold and the Coppers are a different driver altogether. While you can do a lot to shape or tune a sound signature, you can not to my knowledge tune a single dynamic driver to be faster. Changing the speed of a driver requires a physical change in the driver itself.
Just my hypothesis. I also think the Coppers need to be referred to as 'balanced' rather than 'neutral' as some have said.
Interesting analysis!
Did you see the thread on the new phonak filters? People are saying the sensitivity changed just based on the filter, while the driver is the same. Like you said, the cables seem a little different on the monster flavors, too.
I don't know that Noel's comments in that interview back up point number 2, though. Noel (we're on a first-name basis) seemed to be saying that the golds were an optimized and tuned version of the original turbines, with better build and cables.
I think it makes more sense that Monster would develop two drivers (turbine/mtpg and mtpc/md) rather than three (turbine, mtpg/md, mtpc), but I'm just making things up at this point. Not sure about the copper being faster, I only got to hear search's md for a short time, but it could be. Is the speed of a driver really something that can't be altered to give a little less speed? If Noel was saying the mtpgs are an optimized version of the original turbines, aren't the golds quicker than the originals?
Anyway, fun to think about.
