Focux
Hi, I'm using the ER4S
oh nice, i have the ER4SR hope they pair well
DX120 has no problem driving them sufficiently. Even using low gain, I'm not going higher than half volume, and my ears aren't the best anymore.oh nice, i have the ER4SR hope they pair well
I can confirm folder play option doesn't work even after reboot and full rescan of library Actually player goes to next folder chooses the last track there and stops. Not the expected behavior for sure.
Are you using directory view or artist view? I thought that the other day I got it to work in directory view, but now that you mentioned it, I do remember also seeing the behavior that you described..going to the last track of the next album and stopping. Not sure what view I was using at the time. No time for further experimentation at the moment.
I am using folder view and seeing this behavior. Haven't tried artist view as I do not use it. I have everything organized in folders and listen to discographies album by album so the order of folders that I set is important for me
Stay updated on iBasso at their sponsor profile on Head-Fi.
New firmware for the DX120 is now available! Enjoy and always, Enjoy the Music!
http://www.ibasso.com/down.php
I have installed the Update and waited for it to re-boot as per the instructions. Why is all the wording greyed out. Does that not mean it has not automatically re-booted and I i have to turn it on/off manually to do a factory reset?New firmware for the DX120 is now available! Enjoy and always, Enjoy the Music!
I have read the manual and the instructions that came in the readme File. It states that the DX120 will re-boot when completed. How long does it take to update? I looked after five minutes and it was showing everything in a grey state. I assumed it had re-booted. I can go into Settings and Advanced but am not able to read the categories thereafter as they are too faint. Any help would be appreciated, as it is in a state of limbo at the moment.The manual says to do a factory reset at the end.
