debitsohn
great thanks!
question. sorry if someone said it already but how well can these power a T1?
great thanks!
great thanks!
Would I get good results feeding my iMod into the PB1 with balanced phones the other end or for the full benefit does the input also need to be balanced?
Also, what will you guys be feeding into the DAC when it comes out? Guess there's no mileage in that for me is there? or would that better the iMod between the PB1.
I feel a bit dense really but both balanced and DAC's are not something I've gotten into yet, still a noob really
I'm hoping someone can add clarity because I'm quite taken with the whole balanced thing and will probably pull the trigger soon, just not sure if I need the DAC also..
Thanks in advance.
Nigel
I took off the top for a quick look. Most of the large components such as volume control, input/output jacks and battery with a plug connection are mounted on the top of the board. Very neatly done. The workmanship that was evident with the top removed is the equal of any high-end device, regardless of cost.
I did not remove the bottom, as it didn't lift right off as did the top. About all that will be visible are SMD devices, I suspect. One of these days, I will completely undress it for a detailed look-see.
Ron
