Holo Audio Red Streamer
Mar 27, 2024 at 1:32 PM Post #1,636 of 1,845
Yeah, seems to be a decision to only allow one service at a time. However, Roon now recognizes Red as a Roon Ready Device after 2 OTA updates. I have an older Red.
If you don't use Roon, it would be best to move to Ropieee or an older Red OS, IMO.
For me the problem is:
- The current Ropieee is crackling in using NAA or RAAT with the Red
- The new RedOS don't allows two services at once
- Jussi's NAA image has only NAA included
Mar 27, 2024 at 1:47 PM Post #1,637 of 1,845
For me it doesn't even work. It acts just like before, with that buggy version: it boots, but then it freezes.
I remember you had the same issues with me (after the device boots, software force shut down the unit because thinks that is a serial missmatch).
Although my serial number is one of the latest as your's, i installed this version: https://josmagnah.stackstorage.com/s/Z3gU3ycnREPvPM4v after installing it, do all the updates (they are many) and you will finally end with 2024.02.16. The image that DIDN'T work with my device is this: https://josmagnah.stackstorage.com/s/r27HBrkzLSrfMgAi
Mar 27, 2024 at 11:16 PM Post #1,641 of 1,845
I've just installed the latest update, version 2024.03.27. Despite the hassle of selecting different sources, I'm keeping it because I can hear a significant 10-20% improvement in sound quality. I'm really impressed!
Mar 28, 2024 at 3:59 AM Post #1,645 of 1,845
The main reason I've bought Red was Tidal Connect. With almost every update a new issue appeared :relaxed:
  • Recent Tidal app was unable to connect
  • First MQA unfold disappeared
  • Android 13 was unable to connect
  • Still no hi-res FLAC support
  • Multiple service support gone (using UPnP beside Tidal)
Mar 28, 2024 at 6:54 AM Post #1,646 of 1,845
greetings
i am on latest firmware
what is the best setting for holo red connected to holo spring 3 kte via usb, is it better to use roon or suzeezlite and what is the settings i should chose for each wether it is roon or squeeze lite )
also should i check the the box for USB -> Holo Audio UAC2.0 Gen2.1 Enhanc
Mar 28, 2024 at 6:57 AM Post #1,647 of 1,845
My Red arrives on Wednesday, I'm very excited.
I've read that the HQPlayer OS is recommended here, I'm interested because I also want to use Roon, I currently do this via an RPi4 with DietPi, so I can easily choose between Roon and HQPlayer, I then control both with Roon.
What about the HQPlayer OS?
Do I need HQPlayer Embedded for this?
Mar 28, 2024 at 7:00 AM Post #1,648 of 1,845
I also want Tidal Connect Hi-Res... let's hope that they will release a new firmware to support it
Mar 28, 2024 at 7:09 AM Post #1,649 of 1,845
Is the new O/S available somewhere other than through the Red O/S? I don't have the Red O/S flashed and I'd rather just download it and write it to a new card.
Mar 28, 2024 at 7:44 AM Post #1,650 of 1,845
  • Keek
