The latest 5.5 HQPlayer OS image really improves things even more! Also when using Roon as frontend.
Holo Audio Red Streamer
- Thread starter lsantista
incredulousity
Thanks. I’m using an older version which is good. Guess I’ll update to the new image.The latest 5.5 HQPlayer OS image really improves things even more! Also when using Roon as frontend.
steveoat
- Jun 17, 2012
Is there any way to update the Holo Red to the newest version of HQ Player NAA?
Burn the NAA image to a card, insert and reboot. Or do you mean update the holo provided software? I’ve never used the holo software but I expect you’re tied to their image releases.Is there any way to update the Holo Red to the newest version of HQ Player NAA?
Sure. Just use the file at https://www.signalyst.eu/bins/hqplayerd/images ( see also https://www.signalyst.com/embedded-install.html )Is there any way to update the Holo Red to the newest version of HQ Player NAA?
You can choose using the HQPlayer OS (which has NAA, upnp etc features) or the fully optimized, pure NAA image.
spacecase25
no need to modify. the NAA image already boots from memoryThat's great, ramroot is one of my consideration. Meanwhile, can HQ NAA being modified using ramroot to run?
incredulousity
Updated to the current version. I think it sounds better too.Thanks. I’m using an older version which is good. Guess I’ll update to the new image.
The same here, Tidal plays MQA. Also no info in log about Tidal Connect. Maybe in the next update...I downloaded "HoloAudio Red-OS-20231221 (serial 2305 or higher)" firmware and working fine with Red serial less than 2305. I see option "Red Native Output", not sure what for?
Tidal still runs at 44.1KHz and 16 bit with new firmware.
What's the best output to use on the RED?, I am currently using i2s to my holo may kte.
Solasuke
- Feb 8, 2016
USB, then you use the May’s clock which is better.What's the best output to use on the RED?, I am currently using i2s to my holo may kte.
incredulousity
USB, but if your cables and power are good, i2s is pretty close, but not identical.What's the best output to use on the RED?, I am currently using i2s to my holo may kte.
I use USB, it was better than i2s when I did some comparison (Red -> Spring 3). Of course, different USB and HDMi cables were used and cable matters also.
are you using RedOS or other OS? for RedOS try the link and use the older 2G version, it can do the first unfold of MQA.The same here, Tidal plays MQA. Also no info in log about Tidal Connect. Maybe in the next update...
https://magnahifi.com/holo-audio-product-downloads/
I'm waiting for hi-res FLAC.are you using RedOS or other OS? for RedOS try the link and use the older 2G version, it can do the first unfold of MQA.
which HDMI/I2s cable do you used in this comparison?I use USB, it was better than i2s when I did some comparison (Red -> Spring 3). Of course, different USB and HDMi cables were used and cable matters also.
