HDMi cable was Chord C-View and USB cable was much more expensive Intona Premium (highly recommended USB-cable).which HDMI/I2s cable do you used in this comparison?
Holo Audio Red Streamer
- Thread starter lsantista
kenz0
- Feb 8, 2009
I`m primarily looking for DDC around 1k, to do PC->USB ->Chord Hugo TT2->headpones/stereo setup. Streamer looks like an option.
Has anyone compared Red to other price-relevant DDCs, Singxer SU6? Any feedbacks?
spacecase25
I (am currently) use i²s with my Spring 3 KTEWhat's the best output to use on the RED?, I am currently using i2s to my holo may kte.
Sound Eq
- Nov 9, 2013
greetings
I will get the holo red tomorrow with the spring 3 dac, i use roon
can i ask what is the best way to connect my set up
are there great i²s cable recommendations that are reasonably priced
another question is it ok to stack the red on top of the holo audio spring 3
spacecase25
I recommend trying both i²s and USB. All you need is a decent HDMI cable. I bought a super short one from blue jeans, it works and sounds excellent.greetings
anyone on the latest software on Red OS, just saw its available for update on the Web UI, it's 16th Feb 2024 Roon Ready software. I updated it and now it seems you can only enable 1 music service at a time, u no longer can have Roon + NAA + Squeezelite + others enabled at the same times.
Anyone has any experience?
The same problem here, just reverting the OS...anyone on the latest software on Red OS, just saw its available for update on the Web UI, it's 16th Feb 2024 Roon Ready software. I updated it and now it seems you can only enable 1 music service at a time, u no longer can have Roon + NAA + Squeezelite + others enabled at the same times.
For me it doesn't even work. It acts just like before, with that buggy version: it boots, but then it freezes.
Hopefully we will be able to enable NAA and Roon simultaneously again in future.
IDK if just having the one service enabled is a roon-imposed limitation (they can be quite strict with how devices need to operate before they give a 'roon ready' badge from what I hear) but that's a bit of a key feature for me so hopefully it can be changed
Does anyone have a copy of previous firmware?
See link
https://drive.google.com/drive/folders/1EtYOpFXxImifIbQdJTmt-ABp8eItT_ao?usp=sharing
If you have versions that are not represented in this share, message me and we can coordinate an upload.
RestoredSparda
- Nov 28, 2010
Yeah, seems to be a decision to only allow one service at a time. However, Roon now recognizes Red as a Roon Ready Device after 2 OTA updates. I have an older Red.
If you don't use Roon, it would be best to move to Ropieee or an older Red OS, IMO.
here's a folder where I've collected four instances from the internet - https://drive.google.com/drive/folders/1EtYOpFXxImifIbQdJTmt-ABp8eItT_ao?usp=sharingDoes anyone have a copy of previous firmware?
i cannot download 27.03.2024 software...the progress bar is stuck at 0%... anyone else with the same problem?Yeah, seems to be a decision to only allow one service at a time. However, Roon now recognizes Red as a Roon Ready Device after 2 OTA updates. I have an older Red.
I very much recommend the HQPlayer OS, you can try for free.
