tupac0306
- May 11, 2011
1+2 really sounds attractive, I have heard from a few people saying it's the best universal IEMs. How does it compare to JH13? I have already heard 1+2 is better than JH16, 334, K3K3 and etc. And how is the fitting? Is it comfortable enough to wear like 2-3 hours?
I will do a detailed comparison with my CIEMs when I have the 1+2 demo unit.
How I feel about the jh13fp. I think you'll quite like the 1+2 but for different reasons. Best universal I've heard and we all know customs are a hassle. Worthwhile in my and your case but...
The hand made part is not that big an issue as they will still make castings taken from the actual molds. It is difficult to adjust an existing silicone ciem to fit. With 5 bores, it might be more difficult to keep them all acoustically free of ear geometry induced attenuation as there are 4 at the perimeter. I'd hope it was something like that instead of them just varying that much. My left ear has that sort of issue and I actually took care of it myself instead of doing the back and forth thing a few times. Not something I'd recommend for others but would have been impossible for me with silicone. I also probably got it better than I could have without sitting next to guy doing it. The majority of customs come out just fine but anyone not prepared to go through a bit of adjustment after the fact should probably think twice. Buying overseas only amplifies the point.
