Nice. Me, too. I just upgraded by HE1000SE.New member of the Susvara fam as of tonight!
Have it on my ears now running through our Pro iDSD and Pro iCAN and am pretty much at a loss of words.
HiFiMan Susvara
LarsMan
Mine are so old all that lettering is worn away! They still sound magic, though, and will sound even more magic when my Auris Nirvana shows up tomorrow with a lot more high quality juice than anything I've currently (ahem) got...Took some macro shots of my sus
ufospls2
- Dec 9, 2014
I'd highly recommend also trying it with your MSB analog DAC and S-200 amp, you may be surprised at the sound quality.Mine are so old all that lettering is worn away! They still sound magic, though, and will sound even more magic when my Auris Nirvana shows up tomorrow with a lot more high quality juice than anything I've currently (ahem) got...
SuperBurrito
Nice macro shots! And build quality looks good close up.Took some macro shots of my sus
Benno1988
At least they are metal. Though for the price tag, really should be rocking a better cable, higher quality pad material, headstrap that doesn't feel like velvet cardboard from a craft store and the black mesh not looking like a untensioned flyscreen. That's my nitpicks, otherwise I'm enjoying themNice macro shots! And build quality looks good close up.
I would like some thicker softer earpads and better looking cable. I don't mind the headstrap.At least they are metal. Though for the price tag, really should be rocking a better cable, higher quality pad material, headstrap that doesn't feel like velvet cardboard from a craft store and the black mesh not looking like a untensioned flyscreen. That's my nitpicks, otherwise I'm enjoying them
Benno1988
I put the Dekoni Fenestrated Sheepskin on. Much nicer, feels more premium.
I can't help but nitpick every items design choices, so take with grain of salt. They are the best built Hifiman.
Thankfully I can just make myself another cable when I could be ****ed.
LarsMan
I recently got those too, but I've not put them on yet - I hate replacing earpads like these - why can't everybody use magnets like the Empyreans? And that leather headstrap? I got a used pair and that's the first thing I had to replace - it was really funky and flopped back and forth. And I've never much liked the Hifiman metally look (at least they're not shaped like the HE-1000's), but they are pretty comfortable, and I'll put up with a lot of nitpicks for that SOUND!I put the Dekoni Fenestrated Sheepskin on. Much nicer, feels more premium.
Benno1988
I found the Dekoni pads not too easy to put on.
First obviously get the stock ones off, involves trying to compress the ring a bit and pop the first tab out.
The Dekoni blue ring is stiffer / thicker than the stock, so its not as easy. At least mine was, so it needed a bit of elbow grease. Can give each tab a bit of a nudge/bend inward to help loosen it to begin with.
I ended up;
1. Align pad seam to connector socket
2. Pop in first tab on the side, so press toward driver and slide it across
3. Repeat for the top tab, now keeping some pressure diagonally up to keep them in place
4. Other side tab next. This involved pressure on the side of the ring inward then press toward driver over the tab to pop it in
5. Last is the bottom tab, now hardest. Using a small flat screwdriver (the little craft/glasses ones) and a light, jamb it into the remaining tab and push up until it flexes enough and grabs the ledge, then push down on the pad over it to pop it in
Now they are never coming off.
I ended up;
LarsMan
Thanks for that tip!!! I'm going to have to recruit an assistant as my 70-year old fingers (and 70-year old brain) are just not up to this!I found the Dekoni pads not too easy to put on.
I ended up;
LarsMan
Thanks, FooFighter. And I'm a fan of Dave Grohl, too!
FooFighter
Congrats for the incoming Nirvana.Mine are so old all that lettering is worn away! They still sound magic, though, and will sound even more magic when my Auris Nirvana shows up tomorrow with a lot more high quality juice than anything I've currently (ahem) got...
Have you considered Wells Audio Dragon before for Susvaras?
Heard magical things about that combo
Benno1988
The fresh Dekoni ones with the blue ring, first time in, took a whooole lot more push that that. Might work with credit card, and may have just been my set of pads, but it needed a fair bit of convincing.
ra990
Slipping a thin credit card between the ear pad and headphone to squeeze the ring in and release the clamps or attach them has always worked for me.
Total: 44 (members: 14, guests: 30)
