Susvara is very revealing of your equipment capabilties. Right now my current set up seems to introduce a bit of noise since timbre and clarity seems to be affected negatively when compared to the Tungsten DS with UP pads. At CanJam NY testing both headphones on high end amps tells me that the Susvara and Tungsten are just different presentations of high quality sound.Very cool.
I would be interested to hear your thoughts on the Susvara vs Mod House Tunsten DS!
Susvara vs Tungsten on my Bliss - May setup:
Susvara has good subbass extension. This makes a difference for hip hop, heavy rock with a lot of low bass, kick drums, etc. Tungsten rolls of the sub bass with my current pad so it loses some of that energetic bass that makes hip hop bop your head, or that throb from a well placed bass strum. That being said, upgrading pads or cables can bring back some of the bass, or go high end and it will thump.
Mid bass performance: Susvara without a high end amp can sound reference. It is clean bass but without the energy that resonates in your head. Tungsten typically delivers more energetic bass in this area where it adds a bit more weight to the notes. But sometimes without sub bass it just sounds a bit flat. But overall when Susvara doesn’t move you with mid bass the Tungsten can deliver that thump. On balance, in this department, Tungsten has the fun bass you’d expect from a headphone like a Susvara.
Midrange: they both great but the Tungsten adds a bit more weight to vocals so they’re not as thin on the May with no oversampling.
To be continued since Mobile Safari crashed and are my second half of my review
But to conclude: Susvara is still a king headphone because it delivers a cohesive reference sound that can hang with the high end like the He-1 while the Tungsten can challenge Susvara with exciting energy and mid bass, with thicker sound in vocals, imaging, dynamic range. It is easy to tailor the sound with different pads and grills and is better suited than Susvara for media watching.
