HiFiMan Susvara
Apr 28, 2024 at 2:54 PM Post #25,591 of 25,688
Apr 28, 2024 at 4:00 PM Post #25,592 of 25,688
I’ve been comparing the stock with Forza noir hybrid, and the stock is a little taller sounding I think and the Forza is kind of more in the center and more sub bassy. Any other compared the stock to Forza noir hybrid ? (I have the 4pin furutech plug)
May 1, 2024 at 8:45 AM Post #25,594 of 25,688
Mjolnir 3. While both rag2 and mj3 3 is similar in the staging width, mj3 goes deeper and thus more open. I think the better refinement from mj3 gives it that deeper perception. The Zhal HM1 is the direct upgrade to the Mj3 if you want to find to keep all of mj3’s strengths and push them even higher
May 1, 2024 at 9:44 PM Post #25,595 of 25,688
with all the talk of the susvara stock cable I decided to take mine out of mothballs and give it a listen tonight...it is as hideous as I remembered in terms of aesthetics but I must say it actually sounds darn good!
May 1, 2024 at 9:51 PM Post #25,596 of 25,688
Speaking of cables, if anyone in the US is interested, I’ll be selling my DHC Chimera soon. It’s a bit too short for my needs.
May 1, 2024 at 10:07 PM Post #25,597 of 25,688
Yes. Stock is really good tonally and technicalities are certainly impressive for a stock cable! I've been advocating a cable that has these qualities on my earlier post:
Stock is a great benchmark, but I agree with you that pulling off the exact stock cable tonality and just push everything good about it (more refined details, more sense of layering, more defined texture in subbass to upper bass, more weight to the notes) to maximum levels is the key
May 3, 2024 at 4:10 AM Post #25,600 of 25,688
Interesting. I’m going to do the same. I bought a JPS SC cable ages back for my DiPhi and they also fit the Susvara (2.5mm) and I found that I much preferred it and haven’t used the stock cable with Sus since then. My system has changed a fair bit since and I also got new pads for Susvara, so I’m intrigued now as to whether my thoughts on the cable might have changed.
May 3, 2024 at 9:04 AM Post #25,601 of 25,688
It's now about three years I own a Susvara and FWIW here are the things I learned: It was a giant effort to get them sound great to my ears but I'm glad that I didn't give up. When I got them, I was a bit underwhelmed: while super detailed I found them too light in bass, occasionally too shouty in the upper mids and sometimes sounding a bit compressed overall. I experimented with different amps and although this improved things a little bit, it never sound quite right to me. In the last months I switched to fiber-based network and suddenly it sounded right! Now it sounds punchy, holographic and so big without being shouty anymore! Bass quantity just improved slightly but it seems for the first time that the timing is right. This improved the bass quality and tactility so much that the bass is wonderful now.
The Susvara is really reveals the properties and faults of the whole system and now I can hear about every change I make to my chain. In my case fixing the source was the biggest step I made. Now different amps are just more of a flavour in comparison.
My advice for all people who struggle with the Susvara and have the feeling that something does not sound right: Don't focus only on amps to fix the sound. Maybe you have a source issue that other headphones won't reveal. In my case fixing this was much more important.
May 3, 2024 at 2:36 PM Post #25,602 of 25,688
@infinityShake Do you use fiber all around? How do you Connect your source with fiber? Or do you use fiber conversion kit to Ethernet for source?
May 3, 2024 at 6:07 PM Post #25,603 of 25,688
It's a conversion from Ethernet. I have a dedicated PC running HQPlayer and a Holo Red Streamer. They are connected via a Sonore Optical Module, a Cisco SFP-10G-AOC2M and an Etherregen switch. This way the streamer is galvanically isolated from the noisy PC.
May 4, 2024 at 8:34 AM Post #25,604 of 25,688
Alas, my mighty Ragnarok 2 has croaked. It went into protection and now will not pass the power-on checks. It's under warranty, so it will likely soon be boxed up and be flown across the country to California for service.
This has got me thinking... since Rag is on sale now for $999, I could pick up a new one and use the warranty-repaired original as backup... or... I could always replace the Ragnarok 2 with a Mjolnir 3 + Vidar 2 combo. I use just two inputs on the just-an-amp Rag... XLR from a Lokius (Lokius sources are BF2/64 and Rega Aria)... and RCA from tape deck. I use the Rag to drive a variety of cans from HD-650 to HE-6 to DCA E3 to Susvara, and then it also drives a pair of LS50 Meta w/ a pair of Rythmik F12 being driven from speaker level input direct from the Rag. I love being able to switch between headphones and speakers with a single system.
Question for those who have heard the combo... how is the Susvara + Ragnarok combo compared to the Susvara + Mjolnir 3 combo? Upgrade? Sidegrade? Would I even notice a difference?
Is using a class A MJ3 as a pre-amp to the Vidar 2 kind of a crazy waste of power? (I tend to leave my Rag2 on all the time).
It would also give me the option of introducing a MiniDSP between the MJ3 and Vidar to perform actual bass management and fix timing issues between the LS50 and F12. With the Rag I couldn't do that without also blerping with my headphone audio.
May 6, 2024 at 1:39 AM Post #25,605 of 25,688
Do you guys like susvara for space ambient or is a bit too smoothed over on the edges of the detail?
I compared sus 2.5 mm to 1266 TC and found sus a lot more polished/smooth sounding but maybe a bit too much whereas 1266 tc had more deep textural information.
