HiFiMan Susvara
Jun 2, 2023 at 7:35 AM Post #21,361 of 26,664
Now ,my Susvara are here...
Best Regards
Sisco
And Original cables ,also changed for a Tripowin Altura..
Jun 2, 2023 at 10:05 AM Post #21,362 of 26,664
You guys obviously like posh stands! My cheap and cheerful ones are definitely high enough so the wires are clear of the base. And that is with the phones supported by the metal band.
mine are like around $11 and they’re looking fine to me!
https://a.aliexpress.com/_mtN0rQu
Jun 3, 2023 at 3:43 PM Post #21,365 of 26,664
May I ask what foam cover do you use for the headband? Do you find it increases comfort?
The cover is almost certainly to prevent metal-to-metal contact with the arm of the stand. Your head only makes contact with the strap, so the cover won't have an impact on comfort other than adding a small amount of weight.
Jun 3, 2023 at 6:11 PM Post #21,366 of 26,664
Is Susvara still better with an underpowered tube amplifier compared to the HE1000SE running on the same amp?
Jun 3, 2023 at 6:20 PM Post #21,369 of 26,664
No, don't believe anyone who gives any answer other than an unqualified, emphatic nyet.
If you can’t afford a proper amp take the HEKSE all day. Plus it scales as you improve the chain. You will be very happy with them til you have the right chain
ok thanks so I should stick with the HE1000SE with the Cayin HA-3A tube amplifier and maximise that headphone's potential instead of getting the Susvara and not wanting to upgrade my amp
Jun 3, 2023 at 11:39 PM Post #21,371 of 26,664
I have a Cayin HA-3A and Susvara doesn’t sound as good there. Can get it plenty loud only, but it’s left wanting.
Jun 3, 2023 at 11:56 PM Post #21,372 of 26,664
Jun 3, 2023 at 11:59 PM Post #21,373 of 26,664
100% (if the hekse suits your listening preferences, of course)
