khaos974
- Mar 19, 2008
No, they can't. Speaker load usually extend from 2 to 8 ohms, headphone loads from 16 to 300 ohms, this result in the fact that for the same amount of power to the transducer, speakers require a LOT more current (and less voltage). Since headphone amps aren't usually designed to handle this much current, they'll simply melt down.
This might be better for the tech forum, and is really just audio math chewing gum. I think many headphone amps would adequately drive my speakers:
- 90 dB at 4 ohms at 1 watt at 1 meter (these are not particularly sensitive speakers!)
- listening distance is just a bit over 3 meters (about 3.16 meters)
- average listening volume is 76 dB with peaks to 86 dB at 3.16 meters, which corresponds to about 86 dB continuous with peaks to 96 dB at 1 meter (using the inverse distance law)
- 86 dB continuous at 1 meter is achieved at 0.4 watts
- 96 dB peaks at 1 meter are achieved at 4.0 watts
The Schiit Lyr (if it could handle 4 ohms) would certainly be enough to power these very average efficiency speakers.
All this math seriously begs the question, of course, why I felt the need to buy a vintage Carver power amp that produces 450 watts/channel continuous at 4 ohms since it has over 100 times the power necessary to handle the volume peaks (and over 1000 times the power necessary to handle the average/continuous volume) for these speakers at my listening distance and volume! Geez...
I think it says something about headphone volume and power too but I'm not sure what just yet.
