use the spreadsheet here to calculate what specifications you will need from the amplifer: http://www.apexhifi.com/specs.html
just note that a lot of amplifiers manufacturers do not publish full power specification, so this exercise might not be as helpful as you would like.
So using the HiFiMAN HE-1000 specs of 35 ohms headphone impedance and 90 dB sensitivity, and choosing a rock-concert-sized max volume of 110 dB, I use the spreadsheet to find:
Headphone power calculator
Headphone sensitivity (dBSPL @ 1 milliwat) 90
Headphone impedance (ohms) 35
Desired loudness (dBSPL) 110
Required power (milliwatts) 100
Required voltage (volts RMS) 1.87
Required current (millamps RMS) 53.5
... I need 100 mW into 35 ohms.
Hence, for example, the Oppo HA-2 iDevice-compatible DAC/amp, which puts 220 mW into 32 ohms, ought to be just fine (assuming it does not suddenly drop its input power, given at 32 ohms, more than a factor of two to get up to the 35 ohms + / - 5 ohms of the HE-1000).
Right?
$299.00.
And furthermore, if I am willing to settle for a volume of just 1 dB less, or 109 dB, I can even use my Beyerdynamic matchbook-sized DAC/amp, which puts out 1.7 Vrms into that load:
