Jozurr
- Oct 25, 2009
No, it goes on the plastic inner circumference of the cup, directly adjacent to that.
Thanks. Also, how do you stick the foam from a mouse pad on there?
If the strip is long enough (ie: the length of the inner circumference), it's held in simply by the foam attempting to return to flat.
Otherwise there's always good old adhesive-backed Creatology foam.
Mouse pad has different reflective and vibration damping properties compared to just creatology felt. Like @Armaegis said, If make the mouse pad strip a little longer than the inner circumference of the cups it should hold itself in place pushing outward. Look closely at my pictures, they show the mouse pad starting at the cable connector and wrapping around the gray plastic part of the driver until it returns to the cable connector. Hope this helps!
anyone tryed "Cayin cs55a" with HE-6?
look nice, but no idea about the sound sig. found one for sale locally (1700$) and wanted to ask about it.
I had a Cayin A-70T amp for a couple of years for my bedroom speakers. Also used them with HE 6 from speaker taps. It sounded good with HE 6 but my Marantz vintage PM-500 sounds better. Don't recommend buying one specially for HE 6.
Many people wonder how much money you'll have to spend to properly drive your HE-6.At my big surprise (i usually drive the he-6 in balanced mode with my Violectric V281 and my Audio Gd Master 9) the other day i tried the new iCAN SE by iFi Audio and this new bay boy drives the HE-6 like a mad! With 4 watt at 16 ohm the power is really enough. If you engage the bass boost at minimum settings the sound of the HE-6 becomes full engaging fast and literally neutral.The sound is not as refined as with the Master 9 but for 300 bucks you get very very close. Well worth a try!!!
