Yeah, 15w was never seen as a factory supported number.
I'm sitting on my blown 6s awaiting repair funds. Sigh.......
Got a blown one I'm dying to get replaced as well.
Power meters also have % markings (% of max rated power, I think). These are the lower set of markings and a little hard to see in the picture.
10W doesn't sound right. It produces a LOT more bass and punch compared to the 430HA (8W) and Taurus (4W).
more bass and punch has nothing to do with more power. How did they come up with 90W to begin with? At which load? From their site, it's saying 500W at 1ohm. You do the math then it's 10W. Which is still plenty even for HE-6.
hello guys
can anyone recommend a speaker amp(below 300$) which would give good results with the he-6(not sound worse than an he-500 or 400 with a cheap amp -_- ) till I can afford a proper amplifier... or if that is even possible in this price range!
thanks.
hello guys
thanks.
A mid tier receiver or power amps this would apply. There are amps out there that took the route of the better/best parts in their designs and made some serious effort to present the first watt the best it could. Others compromised and put more effort into a case or a receiver with pre-amp functions. For the vendors that made all-rounders, they used good but not great components. So you get a little more power supply available, not the wattage necessarily. I'd recommend getting monoblock or dual mono amps but that's another matter.The PDF gives full specs - states 90w/8 ohms.
This would extrapolate to 14.4W/50 ohms.
I checked the HE-6 manual. Recommended minimum power is 2 Watts (at rated impedance). Then it is suggested that it's possible to use a speaker amp, and here the maximum power rating is 70 Watts. This translates to 11.2 Watts in HE-6's impedance.
As mentioned, I think that Head-Direct used to have a maximum power handling spec of 15 Watts, but this info is not present anymore.
Does it mean the speaker amps should not be used which have power output of more than 70 watts per channel? My speaker taps are rated at 110wpc and I blew my drivers. Im trying to think of possible reasons other than the fact that I went too loud.
If you play 100dB with a 200W vs a 100W stereo amp, would it make a difference?
In short: yes (referring to the HE-6 manual). The point of specifying a maximum is likely to minimize the risk of blowing the drivers. However, a 70W speaker amp might still blow the drivers if an accident happens. (HiFiMan / Fang Bian apparently think it's safer staying at a lower power rating, so I might be wrong).
It depends on the circumstances. If we talk about 100dB peaks, then there will be no difference since it's comfortably within the limit of both amps. But if you play at 100dB on average, then the peaks will be much louder and if these are loud enough, the difference certainly will be actual. The 100W amp will clip the signal at a 3dB lower level than the 200W amp.
I have used 200 wpc (Rotel RB1080) amp with HE 6. Never had an issue , guess just have to be careful with volume control.
