Just got an HE-6.
I've been having problem with the left earcup's connector. The left cable end's connector nut won't screw to the earcup. I tried swapping the cable's connection, from left to right/right to left.
When connecting Left cable to Left cup –> makes contact but the nut won’t tighten at all (it’ll spin loosely). So when I actually put the headphones on my head, it’ll disconnect after a short while (probably gravity?
When connecting Right cable to Left cup -> makes contact, and nut will tighten, but a very awkwardly. This is still largely untested, but it makes a more secure connection than "L > L” ever would.
When connecting Left cable to Right cup -> makes contact, and the nut will tighten without any awkwardness
When connecting Right cable to Right cup -> makes contact, and the nut will tighten without any awkwardness.
I checked the firmness of the connection by giving it a very gentle pull, seems like “L>L” just won’t connect securely, gravity itself will disconnect it. As where the same amount of gentle pull on the right (with the other combinations) will be just fine.
I also tried using the spare connectors (two of them) with the left cup, and they seem to screw the nut better than the left cable would; but I’m not very certain (I wouldn’t isolate it to a cable issue yet).
At the moment, I swapped between left and right connections, and I wear the headphone backwards too (L to R). I've also put adhesive-putty (like gum) to help secure the connection. Seems to be OK so far.
Is it known if the HE-6 can be worn as an "ambidextrous" cans (of course, with the L/R channels swapped)?
Beautiful sounding headphones, with industrial design flaws.
