Did you just get HE6 ? I had the same problem, I email hifidirect and got a replacement for free.
Ok no worries I'll try that had them no more than 3 months what are my chances! Didn't notice when I got them.
Is there a mod for a longer/extended gimbal slider/yoke rods?
That's the price I have to pay to have the HE-6 fit better? :/
And I'm heavily considering it; these just sound so amazing.
Is the headband simply not large enough for you? or is it a comfort issue?
Modding *yourself*, now that's commitment.
Yesterday I made up an extension cable to allow the connection of the He-6 to my Odyssey Khartago speaker amp.
I used Kimber Kable 4VS as this seemed a decent quality (but not too expensive) and it had a form factor that was useful for my purpose.
4VS is constructed of 8 insulated strands braided together (4 grey, 4 black, each containing varying gauges of copper wire). I used 2 each of the grey and black strands for the +ve and -ve of each channel.
At the moment the cable uses bare wire at the speaker end and terminated in a female Neutrik xlr for the he-6.
Internals of the Odyssey Khartago below - its rated at 130wpc/8ohms, which gives around 20wpc/50ohms. This amp has the extra Capacitors, parts upgrade, black board, wiring upgrade - and subsequent to this photo has also had the WBT silver Nextgen binding posts fitted. Used with my Harbeth speakers, its a very nice sounding amp.
Anyway, I've had a chance to do some preliminary listening comparing to my Violectric v281.
Preamp used with the Khartago was the Jeff Rowland Capri S2.
Source was mostly hi-res music from my NAS>Mac Mini>Ifi usb power>Grace m903 DAC.
Bear in mind the new extension cable only has a few hours on it - not sure if I expect much change though.
I set levels by ear. This was hit and miss - sometimes I'd change the level and my preference would change.
I'm not sure what I was expecting, but perhaps something miraculous after all the postings on using speaker amps.
That didn't really happen.
The Khartago sounds fine enough, but it certainly doesn't blow away the 4Wpc/50ohms v281. The Khartago does have a somewhat more powerful bass and an overall slightly warmer, weightier sound. The v281 actually may have the edge in clarity - perhaps partly due to its balance, its slightly less robust but not in any way lightweight.
To check out soundstaging and space reproduction I listened to some of the Chesky recordings: Amber Rubarth - Sessions from the 17th Ward, CC Colletti - Bring it on home, David Chesky - New York Rags. Not much in it and I actually preferred the sound of the v281.
Sometimes I'd think the Khartago was preferable and then I'd switch to the v281 and my preference would change - often it was a toss up.
One thing I can say though - the Violectric has the quieter/blacker background, which may be another reason why it seemed to have the edge in clarity.
This is not to say the Khartago is noisy - its almost dead quiet - but I can hear a faint hiss between tracks, though this is swamped by the background noise of most recordings. The difference here is the gain - Khartago is fairly high at 31dB, while the v281 was designed with low gain to avoid any noise.
My preliminary assessment is that I prefer the v281.
Yes, I know this can not be interpreted as any blanket statement about speaker amps.
Yes, some will diss the Khartago because of its high gain and give any number of reasons why this amp is inappropriate for this application.
Nice write up and some really good information about the Khartago.
Thanks, I've put a further 15hrs on the extension cable and my impression is pretty much the same.
Still, while the v281 offers more clarity, the balance using the Khartago can be more relaxing for some recordings.
I'm wondering how much influence the type of speaker cable I've used is having - the extension is 3 metres in length.
Having now heard the balance I'm getting, I wish I had of gone for the more expensive Kimber 4TC which is similar to the 4VS but uses Teflon insulation. Its said to have better high frequency clarity. Knowing what the Khartago is capable of - and the he6 - I just don't feel I'm getting the best from it.
I'm tempted to buy some 4TC and make a second cable. What are other people using?
I had good results with Mundorf Gold/Silver wire, 24 awg. (5mm).
