TMRaven
- Apr 6, 2011
Thanks, major help having a free version.
I took your advice and used yong's vst wrapper. However the electri-q plugin still has some bad bugs.
It doesn't crash foobar, but saving presets is just impossible. If I edit a 'user' preset and give it a custom name things go bad. When I select that specific preset it gives the 'incompatible preset file' error. Also It seems to forget my presets until I reboot foobar.
Is there a way around this error?
p.s. saving different presets under the original name 'user' is unacceptable.
I'd be all on the jmoney pads if they had the build quality of the audeze leathers.
Yeah...I had the chance to try out the LCD3 earpads for a few days recently, and its build / material quality is just perfection. The lambskin is so impeccable and treated to be so soft that it literally felt like nothing when you touched it. Quite a far cry from the J$'s which are more...handmade, so to speak.
