raybone0566
the rings from head-direct.
Did you try contacting hifiman directly? Perhaps they could sell you replacements or give them for free. Not sure whether warranty covers this but worth a shot.
In the worst-case scenario, you could get a pair of replacement earpads and use the rings they come with. Not cost-effective but if there's no other option...
good point, I will email them, there is one more thing, which is...kinda strange
Well, I will try...
Fearless1 - I will not please you, I am from the Europe, which would be so so so much expensive, but thank you, I appreciate it.
Well, other than that I can use it even it is broken - I broke it while wearing on the Brainwavz replacement pads (from my own HM5s), but I was successfull with wearing on the new angled versions now - it is so tight, but it works
And the last, but not least - I finished my paint mod today - I have to buy few of the screws (which holds ear cups with the metal pieces), because mine during diassembly just sc*ewed up (damaged head cross)
Till then, there are a few shots of the painted cup and headband:
here you can actually see, how is that plastic ring not straight enough due the earpads are noticeably smaller, that actual ear cups
Well, I will try...
Well, I will try...
Thanks so it turns out a Nintendo 3DS game case is the perfect size to just keep them from compressing. For the 400i, at least.
Also just wanted to say it was dumb of me to consider selling these, they really are awesome. I'm gonna try to mod them some. probably fuzzor, then compare it to a fuzzor mod with foam instead of felt, to see if the treble backwave can be damped some.
Interested on this. If only I would know a specific kind of material (e.g., felt, silk, specific type of textile, etc.,) that woukd tame the unwanted treble peaks, I'd be very happy.
and finally the final result (assembled)...paint job done.
