htr2d2
- Aug 6, 2014
So after wearing these headphones for the past day and half, I'm noticing what feels like pressure on the left side that is causing discomfort in my cheek and jaw. Any want to fix this?
Since it has not been stated and I don't want to assume the obvious, if clamping is the culprit, there is a steel band in the headband you can flex outward a few times to remove some of the clamping or pressure.
I own the pleather, velour, and focus-a pads. I found the velour to be the least comfortable. The padding is stiffer out of the three. The focus-a pads are in use now and they are so comfy. It is unlikely I will ever install the others unless I am testing--one of these days I am going to build a measuring device w/a mic.
If not helpful, apologies.
