TMRaven
- Apr 6, 2011
You might as well try the stock pads for a week or two, then put the velour pads on.
Just received my HE-400 about an hour ago. I also received velour pads... Is it worth it to put them on or try the stock pads for awhile? I also now see that the X3 sounds good but the HE-400 likes power. They sound really good with the X3 but I do have to give them a little extra volume.
Stay updated on headphones.com at their sponsor profile on Head-Fi.
Is it related to the bass only or the total spectrum ??
The problem now is that you'll focus on that all the time :mad:
Contact Hifiman and get a replacement !!
switch tubes also on pan am to check, and try
Exactly! I'm already doing that unfortunately. I'm not sure if it is just the bass either, at first I thought that may be it as well but it will take some more listening to put my finger on it. I'm going to measure the impedence & go from there.
Yep, tried that as well!
http://www.headfonia.com/mike-and-lieven-on-the-hifiman-he-400/3/
Try this^
Try this^
Thank you for that, I actually read that before I received the headphones & already forgot. It's a shame that I may have to do that with a brand new item but things happen, I really like these so I'm not going to let something as simple as that ruin my experience.
Not to mention that it's very easy to drive. I can get good volume right from the Ipod's out at max volume (though lacking punch). With something very basic like a Fiio E17, I'm already getting all the amplification I need.
Amping the He-400 with the Violectric made it too bright/forward sounding for my taste. On tubes it is a lot smoother, lush sounding and laid back, but no way near the HD650 laid back. Tubes for me is the way to go with these headphones. I was absolutely surprised about the changing character of the HE-400 when using a different amplifier.
