MrMateoHead
- Oct 22, 2012
Pleather, haven't had a chance try the velour yet.
Also, is a good seal important for getting the best SQ? These ear cups are very big and a small part of the pad behind my ear is not touching my skin.
Actually, a broken seal might actually sound better in some ways. Try it out for awhile and see what you think. Otherwise, yes, I would try getting a good seal. You may have better luck with the velours, which are a bit bigger and thicker and so might hit your head right. Remember that you can also twist the cups (pinch the hifiman logo and headband tightly with one hand, the connection is weak there). You may want to try adjusting the reach of the cups to - the headband might help keep things firmly in place.
