Grado77
- May 24, 2010
It seems I can't get rid of D5000 & HE-400. Most guys here recommend them in my price range (and even many guys prefer them to the more expensive HE-500 and D7000).![]()
But again when I'm sure enough about buying HE-400, a kind guy says take a look at DT880 or Q701 or HD600, they are much more accurate and detailed than HE-400 or D5000 which are a little bit fun sounding and It makes me to read and ask more and more.
Thank you very much WiR3D & jerg & IEMCrazy.
Dear IEMCrazy, When I was talking about those kind guys who recommend to look at HD6500 & ..., I didn't mean you. Your reply was really illuminating and useful.
I use Fiio E10 with my K240S and it sounds good, but now I want a much greater headphone and so I want a new amp too. In your opinion If I use an amp like Matrix M-stage or Objective2, HD600 is much better than HE-400 or not?
If you want the truth, I'm a little bit worried about HD600's sound. You know, I mean these huge amount of good words about them that you can hear everywhere, seems a little bit exaggerated to me. But anyway back to the topic, about HE-400 soundstage, which one's soundstage seems to you more natural, HE-400 or HD600? I don't want it to be like a Dolby surround system. I don't listen to classical music. I just want it to be accurate (is this the word?)
and also can someone compare D5000 and HE-400 briefly?
I don't have experience with M-Stage, and I don't have HD600 at present (I decided I preferred HD650 long, long ago), however I can say HD650 has excellent results with O2 if you like SS sound. A vast number of HD6xx owners prefer tube sound with them, however there is definitely a solid SS preference community as well. O2 is dead neutral, I can't comment on M-Stage. But I'd have no problem recommending an O2 as an HD6xx amp. In terms of better than HE-400 on it, that's harder for me to qualify since I prefer both of them on my tubes, and I happen to have used HE-400 a few times more often than HD650 on the O2. Assuming a good DAC/source. And, if you believe in cables, a good cable on the HD650, O2 may be sufficient to give it an edge in SS sound. But don't take that as gospel from me since I'd be much more confident an tube-based performance on nice tubes for both headphones. And there, I think HD650 really takes advantage of the tubes more easily. Something about the high impedance just reflects the tube's sound more clearly. But for a neutral, detailed setup, O2 would indeed work out very well.
For either headphone, honestly.
I wouldn't say that the good words on HD600/HD650 are an exaggeration. We're talking about headphones that have not only survived but with the new MAP, maintained their original value for 12, 10 years or so respectively. No other headphone save for a few studio monitors like the Fostex 40 or Sony MDR-7506 has survived on the market so long and even retained its value. That says a lot about their performance. If you're looking for accuracy. True accuracy in a headphone means a flat, or corrected-flat response. HD600 is certainly accurate. It was designed for classical mastering. you may not listen to classical but that says a lot about a headphone's accurate reproduction. DT880 is just north of accurate. It's accurate but with an accentuated treble to more easily pick up details in tracking/mixing. AKGs are effectively dead-flat. More like HD600 except they're mechanically flat, where HD600 is a "corrected flat" for human hearing. Two philosophies, no right answer. The scientists can argue it out. HD650 is just south of accurate. Very accurate at large, but with a warmed over midrange and rolled high/low ends. HE-400, is "roughly accurate", but it's tilted toward "fun" Ever so slight smile curve. The bass is a little accentuated, the low-treble is a little accentuated (but rolled off in the fatigue range), and the mids are very neutral but ever so very slightly recessed. HE-500 would be the more neutral of the two, though by report and graph they're not wildly different. D5k is the most accurate of the Denon range, while D7k and D2k are slight v curves. D7k would have a bit more refined detail and a bit more of a stilt toward the treble and away from bass.
Two completely different headphones entirely. I bought D5k to compliment HE-400, though I more often use HD650 and HE-400 as my main compliment. HE-400 is right down the center. Slightly fun, never analytical, but generally accurate (enough.) Excellent bass detail, extension, and presence for an open can, but nothing ground-breaking compared to closed cans or LCD-2, great throughout the range, does well with everything. Somewhat unique presentation. The most open non-isolating can I can think of. HD650 (in my setup) is an equal all rounder but comparatively brighter, with more refined detail, more compression of frequencies/DR toward center, more focused, less "surrounding" soundstage, but less instrument separation (HE-400 is a champ at separation, HD650 is a champ at integrating into the whole.)
D5k is very different. It's semi-closed. It has DEEP bass extension and substantial presence. That's not to say it's like a Beats headphone that just blasts distorted emphasized bass. It's pretty linear and very tight with only occasional bloom into the mids. The mids on the D5k (unlike 2k and 7k) are slightly forward but not Grado aggressive. It keeps it pretty flat across the range from bass to treble. I would consider D5k, despite the deep bass, to be a bright headphone. Far brighter than HE-400 and HD650 with significant treble sparkle. This makes it somewhat more fatiguing than the other two, but not truly fatiguing. It's excellent like Oderi said for electronic/hip-hop and acoustic instruments like guitar, violin etc. Natural wood. The treble sparkle and wood warmth create that. However I'm not sure it's as versitile as HE-400 for all genres. I wouldn't want to listen to much classical or jazz on them, mixed thoughts on world, and I positively (personally) would end up avoiding rock on them in comparison. Though I can see how some would like it. I've heard D7k is a better rock can.
I do realize your interest is HD600 not HD650 between the two, but I use HD650 as the example since I'm more familiar with it on given equipment and, electrically, they're both very very similar, just with different signatures.
Dude, write a comprehensive D5k vs HE400 vs HD650 review man. You'll be loved for years for it.
Not even exaggerating; if you write it objectively enough and factoring in things like different degrees of amping and all that, it'd be the go-to guide for anyone looking into getting the 'best' mid-fi headphones on the current market ('best' as in, whatever suits their tastes best).
LOL, thanks. Though it would be hard to factor in the possible change you mentioned in the HE-400 thread of the driver tweaks in newer HE-400s. Or the fact that D5000 will shortly no longer existAnd I wouldn't feel right doing an objective review of anything without either HE-500, LCD-2, HD800, or HE-6 to use as a reference for the top end.![]()
