Hidizs Sonata HD DAC cable - new tiny and mighty DAC&AMP
post-15032518
Post #541 of 810
iraparks
Channahon
Channahon
Can someone please direct to full instructions to update firmware to D? Please, I ran the exe. but not recognized so where exactly do i go to change the vendor and product values? It states the Driver Properties but I can't find that, i'm going through control panel device manager? what am i doing wrong. are the numbers that show when running the exe. the correct or are the "ID's" in the driver property correct if i can find them. I'm sure the directions for Dummies are in the forum but can't find them
thank you in advance
post-15032570
Post #542 of 810
Chessblitzer2017
Michigan
Michigan
Age
31
How do you like the sound ira
post-15032712
Post #543 of 810
Duncan
Moderator
yup, that got me too... This will help - as I've said immediately above though, if you have miserable luck like me and it fails, run it again and it should be good!
post-15032842
Post #544 of 810
JSax
UK
UK
Hi all, first post in the forum.
Using Hidizs Sonata ii on a P20 Pro.
Wondering if anyone else has seen the same things I have:
Out of the box worked ok on P20 pro and ipad pro (I think comparable to a very good usb C - 3.5mm adapter)
Flashed firmware D and stopped working on P20 pro but sounded incredible on iPad pro (as experienced for many Huawei users in the thread).
flashed back to ver ii HD firmware and works on both again, but not at the same level it was on the ipad pro before.
I then tried using a usb c hub, and connecting the Sonata again but this time through the usbA adapter it came with- and hey presto, DAC sound again. So now I can plug in with usb C and get good sound when I'm walking around, or plug in via the usb A adapter and a hub when I'm sat down / at my desk and get amazing sound.
So I'm wondering if anyone knows why the sound is better through the USB A adapter than just usb C? I'm assuming there is some form of circuitry in there that activates the actual DAC part of the Sonata?
Anyone managed to get firmware rev D working on a Huawei phone?
post-15033118
Post #545 of 810
iraparks
Channahon
Channahon
My Gosh, Thank you for the help, I would never of known to look to the drop down for "hardware id" without your help. Now the firmware is set to D and the sound is crazy good. FLAC music played on Foobar2000 still states 44100 Hz is there a setting on Foobar2000 to adjust so it plays at 24/192 as well?
Sorry for more questions and again THANK you for the clear up on the Firmware.
Reactions: Duncan
post-15033123
Post #546 of 810
iraparks
Channahon
Channahon
After the help from fellow Forum friends, the sound is crushing it, I have low end Monoprice Retro headphones but the difference from not having the DAC is worlds apart, never new such sound was out there until now. Thank you hopefully I won't be spoiled and can listen to music without the DAC also.
post-15033144
Post #547 of 810
Duncan
Moderator
I'm unsure re foobar2000, but look for something in the settings about resampling (if not in the app itself, maybe in the sound settings of your handset) - I know it is on-app on UAPP for example (and Neutron too IIRC).
Then again, if you're playing in windows - in control panel there is an option for resampling - Control Panel -> Sound -> click on the item you want to update, then Properties -> Advanced -> there are the sample rates available in a drop-down.
Reactions: iraparks
post-15033154
Post #548 of 810
Duncan
Moderator
The only thing I can think of, although if you're walking around - I'm guessing this dismisses it - would be if the USB hub is self powered, so - can give the dongle more power?!?
Re Huawei - I've seen some posts further back on this thread that seem to indicate not :frowning2:
post-15033160
Post #549 of 810
moisespr123
United States
United States
Website
moisescardona.me
No. the DAC only consumes just a few mA of power. A standard USB port is sufficient.
post-15033246
Post #550 of 810
Chessblitzer2017
Michigan
Michigan
Age
31
I don't even notice* any difference as far as battery going down faster. Couldn't say the same for smsl idea stick. For Google pixel
post-15037181
Post #551 of 810
Duncan
Moderator
I'm really liking this dongle - finally convinced me the on board headphone jack is dead on a cellphone.
Reactions: peter123
post-15043963
Post #552 of 810
billbishere
Columbus, Ohio
Columbus, Ohio
Website
www.billbphotography.com
I picked up the generic version of this little guy. Defiantly makes things more dynamic and adds some volume. Tested it on my 58x and ZST's so far, I had ordered right when I ordered my iSine10's but luckily I found the Anker cable for the cipher DAC. But I will try it on those eventually. It makes the ZST's SING - always amazed by these things! Nice improvement!
post-15045692
Post #553 of 810
Duncan
Moderator
Try firmware "D", definitely switches things up a notch :D
Reactions: billbishere
post-15045991
Post #554 of 810
billbishere
Columbus, Ohio
Columbus, Ohio
Website
Ok, just did the "D" firmware. All went as expected. I can tell it added a bit more to the sound and dynamics. I would say it boosted things another 10% or so, it's hard to say because I didn't have much time on the other firmware. But at least I know I am using it to it's fullest potential now.
Reactions: Duncan
post-15050740
Post #555 of 810
baskingshark
Jabberwock Island
Jabberwock Island
Hi, I've gotten the HD sonata after reading this thread, and with firmware D, it is excellent for music.
Just checking if any of you guys find that the HD sonata gets quite warm after using it for about half an hour? Is that normal?
