Nice. I enabled nos from beginning, and haven't tweaked anything yet. Will keep it like that cause I'm liking how it sounds during burn in
Sounds like it might be a match with Traillii??It's in the back of my mind that the slight upper mid forwardness in the RS6 might work well for a less forward IEM. It's one reason the RS6 sounds sublime with the IE 900, but it'll have to consistently pair well with EVO to topple the R8...unless a less mid forward IEM comes along that topples EVO. Damn, this hobby.
Can't say for sure, but R2R does NOT support DSD natively. So either there's an R2R subset in the RS6 designed to handle DSD, or there's some sort of DS modulation separate to the PCM R2R chain. Different R2R DACs have different ways of decoding DSD, not sure exactly how the RS6 is doing it.A question about DSD playback with RS6, either of a file stored on it locally or when using it as a USB DAC on PC using playback software (like Signalyst HQ Player) outputting DSD to the DAC: Based on the circuit diagram below, it looks like the R2R is only utilized for PCM, and is entirely bypassed for DSD. Thus, if DSD is my preferred format, investing in an RS6 to experience the musicality of R2R may be misguided. Is this correct or am I misreading the diagram below?
I appreciate your response, @gLer. It does seem that the circuit diagram is ambiguous about how the DSD input signal is managed. That said, the proof is in the listening, so I will await reviews from trusted sources such as you, @twister6 and others. It would be great if you could comment specifically on the sound quality with DSD source files (local files stored on DAP or using RS6 as a USB DAC receiving DSD rom HQPlayer, FooBar or similar). Many thanks!Can't say for sure, but R2R does NOT support DSD natively. So either there's an R2R subset in the RS6 designed to handle DSD, or there's some sort of DS modulation separate to the PCM R2R chain. Different R2R DACs have different ways of decoding DSD, not sure exactly how the RS6 is doing it.
I asked this point before like yours… still waiting some explanation from the expert.A question about DSD playback with RS6, either of a file stored on it locally or when using it as a USB DAC on PC using playback software (like Signalyst HQ Player) outputting DSD to the DAC: Based on the circuit diagram below, it looks like the R2R is only utilized for PCM, and is entirely bypassed for DSD. Thus, if DSD is my preferred format, investing in an RS6 to experience the musicality of R2R may be misguided. Is this correct or am I misreading the diagram below?
You can choose PCM as your DSD playback mode, if you would like DSD as well as PCM audio to go through the PCM audio system. That would involve converting from DSD to PCM (as so often but not always happens during mastering of music published in DSD, as well).A question about DSD playback with RS6, either of a file stored on it locally or when using it as a USB DAC on PC using playback software (like Signalyst HQ Player) outputting DSD to the DAC: Based on the circuit diagram below, it looks like the R2R is only utilized for PCM, and is entirely bypassed for DSD. Thus, if DSD is my preferred format, investing in an RS6 to experience the musicality of R2R may be misguided. Is this correct or am I misreading the diagram below?
Stay updated on HiBy at their facebook, website or email (icons below).
Stay updated on HiBy at their sponsor profile on Head-Fi.
As part of my review I'm testing DSD converted to PCM vs the same tracks in native DSD, and see if there are any qualitative differences between the two. Honestly, my gut says there won't be much, if any, but we'll see. I know that DSD enthusiasts will always insist on native DSD playback.You can choose PCM as your DSD playback mode, if you would like DSD as well as PCM audio to go through the PCM audio system. That would involve converting from DSD to PCM (as so often but not always happens during mastering of music published in DSD, as well).
This wouldn't be the player for those that are primarily DSD listeners. That said, I would personally question the preference and if it's due to not yet experiencing a great multibit player. https://www.mojo-audio.com/blog/dsd-vs-pcm-myth-vs-truth/ Almost all DSD is mixed etc in PCM.I appreciate your response, @gLer. It does seem that the circuit diagram is ambiguous about how the DSD input signal is managed. That said, the proof is in the listening, so I will await reviews from trusted sources such as you, @twister6 and others. It would be great if you could comment specifically on the sound quality with DSD source files (local files stored on DAP or using RS6 as a USB DAC receiving DSD rom HQPlayer, FooBar or similar). Many thanks!
Have you tried converting DSD to PCM, either on the fly or to WAV/FLAC for local playback?I'm getting mixed result with DSD, amazing performance with MQA and PCM.
I normally convert to DSD, but I leave my PCM file as is.Have you tried converting DSD to PCM, either on the fly or to WAV/FLAC for local playback?
Interesting. What about the shanling do you find better than the Hiby when it comes to sound signature?So far, this thread has influenced me to go with a Shanling M9 for my next DAP. I like my Hiby DAPS, but for ultimate DAP sonics....Shanling.
