It does. Thank you very much!https://mega.nz/file/mXBx1aQR#MaKLBu3u-WocNBIsjKY4SZqDCOLlL8zhfy998ObenUE
let me know this link is work or not
Hiby R6 Pro - serious upgrade to popular DAP
justtsaman
- Apr 15, 2014
Your welcomeIt does. Thank you very mucyou
KarlAgathon
- Jul 3, 2010
I know it’s probably a longshot, but was wondering if there will ever be any more Firmware updates for the R6 Pro?
Since I took ownership of one, I’ve been mostly very satisfied. However, the Wi-Fi seems to get very glitchy at times.
Not even sure a firmware update would fix it, but was just curious In general.
LCMusicLover
Single most consistent complaint about this DAP (and most others)....I’ve been mostly very satisfied. However, the Wi-Fi seems to get very glitchy at times...
KarlAgathon
- Jul 3, 2010
Oh OK, I figured I just got a bad model. So you understand the frustration then I’m guessing
I know nothing is perfect, but I think if people spend a good amount of money on these products, they should work the vast majority of time.
Other than that, when it does work, I think it sounds great.
LCMusicLover
Yes. My 'Waterloo' was the Hugo2/2Go combo. Great sound, awkward user experience, poor WiFi.Oh OK, I figured I just got a bad model. So you understand the frustration then I’m guessing
I do notice my R6 picking up RF noise from my iPhone if they are very close together (within 6 inches or so). Otherwise, I would say its WiFi performance is on a par with other DAPs I've owned (perhaps benefitting from 'lowered expectations').
skycracksopen
- Sep 17, 2016
That’s awesome thanks for testing that!
@Joe Bloggs i‘m experiencing rapid battery drain whenever my R6 Pro isn’t connected to a charging cable, even when the screen is off, no headphones or other devices are connected, and no music is playing.
is anyone else having This issue?
thanks!
Mine started doing this about a week ago. Almost exactly 2 years after purchasing it.
I can fully charge it, play one album, then it usually randomly drops to about 29% battery.
Then I go to start another album, and the sound is very quiet and very distorted... completely unusable after an hour of a full charge.
The only way to keep it running is to leave it plugged in to a power source.
It also won't let me log in to Google Play anymore, so I can't check for updates.
Joe Bloggs
Sponsor: HiByMember of the Trade: EFO Technologies Co, YanYin TechnologyHis Porta Corda walked the Green Mile
It could either be a software issue (needing to enable all permissions for google services, or disable Google Find My Phone, your choice), or a hardware issue (email service@hiby.com ). I suggest trying the software fix first then emailing hiby... Feel free to write back if requiring further details regarding the software fix...That’s awesome thanks for testing that!
thanks!
(1. you go to Settings->Apps and find Google Play Services and turn on all its permissions.
2. is an alternative I have heard of but never explored how to actually do myself)
Stay updated on HiBy at their facebook, website or email (icons below).
Stay updated on HiBy at their sponsor profile on Head-Fi.
Joe Bloggs
That sounds like one for service@hiby.comMine started doing this about a week ago. Almost exactly 2 years after purchasing it.
As for updates, updates for the player are administered by the independent updating app or the update tab inside settings->about device .
KarlAgathon
- Jul 3, 2010
New firmware update
I must confess, I thought firmware updates for this model were long over.
rlw6534
New firmware update
Agreed. Very pleased to see continued support.
Agree! its nice to see this dap still getting support. Thank you Joe for helping out with my player issues!
LCMusicLover
@Joe Bloggs
My R6 Pro says
Current
R6ProInt_1.7G_20191213_1714
But when I try 'Check for Updates' it spins and says
'Checking for updates ...'
and then I get:
Network connection failed(failed to connect to fota5s.xxx.com/119.28.184.101 (port 443) from /192.168.101.20 (port 47288) after 15000ms)
Help please!
My R6 Pro says
Current
and then I get:
Help please!
Is there possible to shared latest firmware just released? My refused go with online update.
rlw6534
As far as I know, the updates are OTA only. I have heard of people having success with removing the SD card and retrying.
