Joe Bloggs
Sponsor: HiByMember of the Trade: EFO Technologies Co, YanYin TechnologyHis Porta Corda walked the Green Mile
I'm guessing that this is because the R6 Pro seems to experience a base ~5%/hr battery drain when the screen is off. I was experiencing this on the current 1.17 and the previous update, and I don't like the idle shutdown solution since it prevents automatic updates and downloads from functioning since when the player is on, I'm usually on the go somewhere without constant Wifi access.
I spent a bit of time in the last two weeks, to see if I could track down the issue and figure out how to get rid of it and it seems that I may have figured out how to reduce the drain to ~0.6%/hr with the screen off.
The source of the battery drain seems to be the Hiby MusicService triggering partial wakelocks with the OS while the screen is off, even if the actual player has been closed and removed from memory.
Since I know of other apps that keep a persistent notification loaded to prevent android from removing from memory or deep dozing the app and/or service, I figured it was worth trying to turn off the the notifications for Hiby. In the end it seems that disabling the notifications for the Hiby MusicService fixes the high battery drain issue when the screen is off.
To try and fix this, I did the following:
- Go to Settings -> Apps & notifications
- Select HibyMusic
- Select App notifications
- Under categories, you'll find two entries, leave Play control bar alone, but turn off notifications for MusicService
I've had this set for the last few days and can confirm that the battery drain seems to be gone, but I can't say for sure it fixed it without a longer period of testing. I've not noticed any issues with playback using the Hiby app, or with the audio quality in the Hiby Player or with any of my other music apps or players, but can't say for sure that there are no actual detrimental effects from doing this.
@Joe Bloggs do you have any info on if there is any reason not to disable the notifications for the MusicService if it mitigates the screen off battery drain behaviour of the R6 Pro? The service doesn't have anything to do with the custom audio stack that Hiby is using does it?
No it doesn't. If you notice your music dropping off sometime after you turned the screen off and left the player untouched for awhile, that would be cause for reversing the changes you made.
Stay updated on HiBy at their facebook, website or email (icons below).
Stay updated on HiBy at their sponsor profile on Head-Fi.
