jsmiller58
Just checking… I believe the R6 Pro II does not support Dolby Atmos or Spatial Audio, is that correct?
RightJust checking… I believe the R6 Pro II does not support Dolby Atmos or Spatial Audio, is that correct?
Right
I noticed these don’t work on Apple Music on the R6 Pro II, hence my question.It should work with Amazon Music Atmos and 360 RA as well as 360 RA on Tidal, unless I'm confused (which is possible). But these are handled by the app, not the device. No head tracking, of course.
Hi all, in the market for an upgrade from my A105 and have narrowed search down to zx707 (Japanese version) or R6 p2.. I mainly use either locally stored lossless files or Apple Music, downloaded locally. Genre wise mostly rock, punk and metal although will throw in a bit country acoustic occasionally. I value a neutral/warm sound but not overly coloured. Soundstage and separation are important.
I have two questions, in my usage case is the Hiby likely to drive me nuts with its battery life or is the sound quality and presentation worth the cost of battery life?
I’m used to the Sony house sound, is the Hiby much of a change?
Both are about the same price here (U.K.) so that’s not a consideration but I want whatever I choose to be my daily dap for several years to come.
Thanks! My a105 has pretty poor battery but still far better than 5 hours. I’m swayed towards a Japanese zx707, the battery life is a big factor. Is the class A amp much of a selling point? I’ve saw many comments comparing the two daps and general consensus is they’re both very capable, surely a step up from my entry point a105The R6 Pro II is less warm than the typical Sony house sound, but still less sterile/digital sounding than a Fiio or A&K type DAP for example.
The R6 Pro II sounds very good for the price, I think it can compete with my Sony WM1A for cheaper, but if battery life is your main criteria, look elsewhere - it only gets about 5 hours on 4.4mm class A. If you are used to the long battery life of a Sony DAP (for example 20 - 30 hours on some of my Sony DAPs), then the R6 Pro II's battery is a far cry.
Additionally, based on your statement of "daily dap for several years to come", battery life is expected to go down with repeated charges. I'm not sure how the battery life of this DAP will hold up if you use it daily in a few month's time.
Just to provide you a different perspective on the R6 Pro II...Thanks! My a105 has pretty poor battery but still far better than 5 hours. I’m swayed towards a Japanese zx707, the battery life is a big factor. Is the class A amp much of a selling point? I’ve saw many comments comparing the two daps and general consensus is they’re both very capable, surely a step up from my entry point a105
thanks for this, may, its a tough decision. I'm wondering if I should try the Hiby just to give me a new sound signature to explore. Your quoted 8 hours sounds impressive, is that streaming or local files? Do you use class A or AB? I'll be driving IEM's (Olinas, 32ohm) so not a difficult drive.I have both - Zx707 and Hiby R6P2. Haven’t touched the Zx707 since I got the Hiby.
The sound quality of Hiby is miles ahead of the Zx707 and so totally worth it. The R6P2 is a very musical DAP much like the Sonys, with a slight warmth. I use Apple Music mostly.
Battery life - I had this concern too. After using it for some months now I can tell you it’s not a problem at all for me. I don’t listen to it 8 hours every day - have work, life, sleep and other things lol.
I would only upgrade the R6P2 if there is a new DAP tomorrow that gives me everything the R6P2 does but with the new ESS flagship ES9039Pro.
What headphone / IEM are you using where you detect a difference between A and AB? I’m not disputing you hear a difference. Since I cannot, I might want to try if I have similar headphones / IEMs to reproduce the same results.I can very definitely hear the sound difference between A and AB so screw the extra 1/2 hour to hour battery life I want the better sound and use A. YMMV
