Hi, I just got the Hiby R6 Pro II, and so I'm still figuring out its quirks. There are a couple issues that I've come across so far. I'm wondering if anybody else has run into similar issues.
1. Crossfade does not seem to work on Apple Music. For example, if I have crossfade set to 4 seconds, the song should start fading out when there's 4 seconds left while the next song starts gradually fading in. However, what ends up happening is that the current song that's playing will just abruptly cut off with 4 seconds remaining, and the next song will start from the beginning. So basically, it just cuts off the last 4 seconds of the song, instead of there being a seamless transition to the next song. I'm not sure why this is happening. I've tried restarting the device, but it didn't fix the issue. Crossfade works on the Hiby M300, and so I'm not sure why this is only happening on the Hiby R6 Pro II.
2. This is kind of an obscure problem, but on first impression, I think I prefer the USB Audio Player Pro's sound quality, compared to the default Hiby Music and Apple Music; Hiby Music and Apple Music sound fairly similar to each other. And so I found that I can get UAPP's sound quality on Apple Music. First, I'll turn on UAPP's bit perfect mode and play a song to verify the sound quality (I have to verify, because sometimes for whatever reason, it does not activate UAPP's bit perfect sound and instead continues to output Hiby's default bit perfect sound. If it's still giving me Hiby's default sound, I will disconnect the USB and reconnect, so that I can get the prompt again that asks me if I want to open UAPP to handle my Schiit DAC. And so after that, I'll play music again, and once I've verified that UAPP's bit perfect is working like it should, I will minimize UAPP and open Apple Music, and wait 1 minute on the Apple Music screen. If I don't wait 1 minute and start playing a song immediately, it won't give me any sound. After 1 minute, my Schiit DAC will reset its sample rate to 192 khz. Then I can press play and start playing music on Apple Music (and the sample rate will readjust to whatever's playing), and it'll give me UAPP's bit perfect sound quality. I was wondering if there was a way, where I don't have to wait 1 minute. Another thing I noticed is that this does not work (getting UAPP quality on Apple Music) if the USB setting under Default USB configuration is set to "File Transfer." If it's set to "File Transfer," and you wait 1 minute and start playing Apple Music, it'll revert back to Apple Music quality. It does seem to work, though, when it's set to "USB DAC (enable USB charging)." UAPP's bit perfect sound is more vocal forward, and it has better speed, dynamics, resolution, clarity than Apple Music.
3. This is another obscure problem, but when I use USB Audio Player Pro on the Hiby R6 Pro II, and I connect it to my Schiit DAC, I get a buzzing/ringing noise when I'm in the middle of a song, and I click the left arrow (previous song) or right arrow (next song), or swipe left or right. This buzzing noise happens for about 1 second before the previous or next song begins. If I want to avoid this buzzing noise, I need to pause the song before I click on the left/right arrow. Strangely, I do not get this same buzzing noise when I swipe up or down (which takes you to the album above or below). This buzzing sound also doesn't happen on the headphone jack when I swipe left or right on UAPP, so I don't know why it's happening only when I use the Hiby R6 Pro II as a transport through the USB port. I have this same issue with the Hiby M300. This buzzing sound doesn't happen with my android phone (S22 Ultra) when I use it as a transport through the USB port.
