danisnowman
Is there any way of hiding certain albums from the HiBy app's album view? I have a large playlist from multiple artists that I'd like to hide from the albums view.
As an interim solution, you might try getting an Anker Powerslim 5000. It’s almost the exact size of the R6 , super thin, and has grippiness to keep it from sliding around. I use a tiny usb to usb-c wire and it’s a pretty sleek setup. (And cheap!My battery has been giving me utter grief lately. Today it discharged in under an hour. I got one song out of it.
When I got home I took the R6 out of the case and the back popped off. The battery has swollen.
I need to get a new one but I can't fine which one to get. Also it's not looking hopeful for replacing the battery without a good soldering iron.
What are my options? Obviously it's out of warranty. Battery date is June 2018.
Bummer about your battery though
You can get it using the Sound filed (sic) plugin for the default HiByMusic player on the R6. Set width to 0 and you get mono.Can any Hiby R6 users help me out on whether it is possible to get mono playback? I’m think of getting a Hiby to hook up to an amp so will mostly be using it line-out. Is there a setting that lets you switch from stereo to mono? I’m a jazz head and lots of the classic recordings sound better when played back in mono. Also, if there is mono setting, how easy is it to access it? Any help on this would be much appreciated.
Stay updated on HiBy at their facebook, website or email (icons below).
Stay updated on HiBy at their sponsor profile on Head-Fi.
That is odd... email service@hiby.com ?My Hiby R6 will not shut down keeps rebooting, i did a factory reset but for whatever reasons it will not shut down completely unless i get to the android robot, then hold power button until it does shut down, i sure as heck don't want to keep doing that. Any suggestions?
Thanks for your help, but does that mean I wouldn’t be able to do that if streaming from something like Tidal?You can get it using the Sound filed (sic) plugin for the default HiByMusic player on the R6. Set width to 0 and you get mono.
You won't be able to do that with MQA tracks on TIDAL on any player because MQA prohibits DSP.Thanks for your help, but does that mean I wouldn’t be able to do that if streaming from something like Tidal?
