Joe Bloggs
Sponsor: HiByMember of the Trade: EFO Technologies Co, YanYin TechnologyHis Porta Corda walked the Green Mile
Hi John,Thanks for the reply - it's good to have someone from Hiby responding.
I've read back over some of the prior discussions of this and I can see that people have been saying that there is audible distortion on the line out if the volume is turned too high. Is this likely to be accurate/ what would you recommend turning the line out volume to in order to avoid distortion?
I have ordered a basic R6 (not a Pro) which is currently arriving in the post.
Thanks!
As the maximum voltage that devices can take on their input varies, it is possible that a high line out level causes distortion, another good reason for having a variable line out.
It would be good if you can consult the manual of your equipment to be connected to the R6, to see what voltage it can take. The max line out voltage of the R6 is 2.1V .
Otherwise, one can certainly play by ear. At lower output gain levels, distortion is avoided while the signal level relative to the mostly fixed noise floor slowly decreases, however this is not a significant issue as long as you don't actually hear any background noise on your amp output in silent passages. (of course, whether this is the case also depends on the capabilities and the volume level of the amp you're using.
Best regards,
Joe
HiBy Music
Stay updated on HiBy at their facebook, website or email (icons below).
Stay updated on HiBy at their sponsor profile on Head-Fi.
