EndGameSearch
https://www.moon-audio.com/black-dragon-mini-coax-digital-cable-75ohm.htmlcould you please place link to that cable?
Somehow i do not understand that in Hiby R6 forum we speak about mp3 files, ok Spotify has 320 kbs, but it is quite bad quality at this time, it was good 15 years ago ( some recordings of mp3 may be really good) but overall on my main system or through headphones i can definetly tell when it plays from Spotify or Tidal. If Spotify will go to CD quality so it will be Tidals death for 100% But till now there is not a lot of options. As in post above those who dont hear difference between 320kbps and 16/44.1 i do not know what they are doing here in forum
I checked this already. The SD card was showing up correctly as an external storage. I pressed the eject and then reinstalled it within settings. I also deleted some old "Android" dat files that were on the card. This seemed to help in performance. Although there is still lag with GUI touch control overall it is better. Thanks for the tip.
Stay updated on HiBy at their facebook, website or email (icons below).
Stay updated on HiBy at their sponsor profile on Head-Fi.
1. I do not have a V20/V30. I'll let someone else answer that question.
2. Are you asking, if you can add a 3.5mm SE Female to 2.5mm Balanced Male adapter to your iSine10, which has a Single Ended cable? If that is what you are asking, the answer is, No. A SE cable cannot be used on a Balanced port even with an adapter. You can technically make such an adapter. But using that adapter to connect a Single Ended IEM to a Balanced port on a DAP will damage the DAP's circuit. The best route is to buy a separate Balanced cable for your iSine10.
3. Unfortunately No. Currently, R6 allows only one EQ profile. Hopefully Hiby will add more custom EQ profiles.
Thanks for the input.
I'll really have to think about it. As I find my iSine 10s sounds really good to my with my V20 EQed with Viper4ARISE.
The balanced interest me more for my Audeze EL-8 TI and Sine, as they require a little more power and don't sound as good out of my V20. There can be a bit of bass distortion in some songs, especially with deep bass. But finding balanced cables might prove difficult. Maybe the Hiby can drive those better even through the single ended jack?
One EQ profile seems quite limiting compared to what I can do through VIper4ARISE. I currently have Five profiles for five different headphones from my collection.
It sounded more like a problem with the touchscreen than responsiveness of the device per se from your description. Maybe you can try typing on the keyboard with a light load (e.g. go right into HiByMusic after bootup and tap the magnifying glass to do a search, type some letters in the search bar) and see which is which?
Everybody has different ears my test was simple i tried Tidal after this Spotify, i'm not saying all tracks but definetly most of them really sounded better. Spotify was using for long time and it is cheaper than Tidal i would use it in any day, but man the quality is different totally either on my Meze 99C or main stereo ( in stereo it is drastic difference) but i has friend he has marantz NA8005 with spotify and Jamo speakers, as speakers are not so high end level, the spotify sound really nice. But again it becomes to preferences. So sometimes equipment plays big role here as speakers can be more forgiving and etc. What headphones you have and amp that can not hear difference?I don't have an R6 but I'm very interested in one and I use Spotify Extreme a lot. It's one of the reasons I would consider the R6 (due to android). I use FLAC files too but I usually can not tell the difference and I have quality headphones and amps. The R6 is meant to be a portable player. Spotify is a great portable app. There are many others, like me, who also have mp3s from the past that they still use.
The wifi range is pretty weak on the dap. Some users have reported poor connection speeds at close range to the router. How far are you from the router? If it's happening at really close range there might be something wrong with the dap itself. Try connecting close to the router and if it still happens do a factory data reset and if it continues contact customer support aka Joe.I honestly don't get it.
Does anyone have any idea as to why the internet connection won't stay on for this player?
Here's what I did today:
1. Ensured R6 was powered off and removed SD card (a Samsung EVO 256GB)
2. Reformatted card via Windows 10 to exFAT (originally exFAT)
3. Inserted card back into R6 and powered on.
4. Got the "new SD card detected" prompt and set it as file transfer (or whatever the opposite of Internal Storage is)
5. Connected R6 to USB and set to File Transfer mode.
6. Loaded a crapload of music.
7. Unplugged R6 and swiped through screens.
8. Result: SMOOTHER and FLUID. No lag!
So is there a correlation between R6 performance and using a preloaded card from another device? I don't know but all seems well now.
Actually all the EQ profiles (9 of them) are customizable, it's just that one of them is named "Custom" with a flat default to make extra sure that you know at least one of them is customizable.
Edit. Word
