evilsync
- Nov 26, 2013
Anyone getting any boot loop issues? Just seems to continually rebooting when it's not doing anything.
I'll need to try the ER4XR then. I just wish Ety would release a proper fitting balanced cable soon for these.
If you have set your sd card as internal it could be that.
There is an explanation of how to boot into recovery mode on the thread. I think it hold Power and vol up and you should boot into recovery.
Choose reset.
wifi disconneting is driving me nuts and the router is only 4 feet away!! signal is stable when i make my mobile a hotspot and share it with the Hiby!!
R6 works pretty well with Etymotic ER3XR
What do you mean, "pretty well"? Direct pair up vs w/iEMatch? I think that's what majority are interested in due to OI.
It was setup as portable, not internal. Not sure if it makes a difference?
It was boot looping all night, dropped from 100% to 44%. What will booting in recovery mode do?
It boots into Androids boot menu.
Just dont choose anything but restart.
Browse on Google . Android boot loop. You will find all the info you need.
