BetterLate
iPhone guy here so it was new to meYes. This is pretty much expected Android behavior that not everyone is supposed to know.
I myself am an Android user since its early days and happens to know.
Ditto on the lack of vocabulary. I am listening with iBasso IT01 and mmmmmmmmmSuperb sound. I don’t have the language to get all technical, all I know is I like detail, musicality, not too much sizzle up top and a nice amount of controlled bass. This R6 just delivers on all. And it ain’t even burnt in.
Try to keep the power button pressed for 30 seconds. Then try one more time to restart (press the button for 5 seconds).Well my R6 now seems completely dead - turned it off for a couple of hours and it now won't power back on.
Small correction : this is how (most) android 6+ devices work. It was not possible to get extended (internal) storage (by formatting your external microsd card that way) with android 5.1 and earlier. At least without rooting and hacking the device (to get similar results with other methods).if you initially formatted the card on the R6 as internal storage, it won't prompt you with any notification. You will just see an extended total capacity of your R6 (R6 storage + mSD's capacity). You have to format it as an external storage in order to see it as removable mSD. I don't have an R6 but this is how all Android devices work.
Wow the train is in fast mode.
Shipping notification SS #755 received !
No worries no stress .... The tracking came by SMS. And I can only see from Texas US.Hmm should I be worried #382 SS over here and haven’t heard anything, also would like to ask who sends the shipping info, indiegogo or hiby?
This worked - the unit is now running again.Try to keep the power button pressed for 30 seconds. Then try one more time to restart (press the button for 5 seconds).
If it doesn't work try to charge up the device and retry.
Hi Rob,This worked - the unit is now running again.
Before I take up @Joe Bloggs kind offer of a return, can someone run through the exact steps they are using to format mSD cards to FAT32 - i.e. the cluster size being selected and whether quick formatting or not (as well as any other considerations on Win 10)? Also, presume the mSD card can only be inserted one way (as per most android devices), which is with the contacts down in the R6's case?
I just want to rule out every last possibility before I give up and opt for the replacement...
Cheers.
Stay updated on HiBy at their facebook, website or email (icons below).
Stay updated on HiBy at their sponsor profile on Head-Fi.
Albeit that I have SS, I just double checked all the buttons and can’t feel any looseness. The tolerances and fit on mine seems very well done. I think unfortunately the fault sounds specific to your unit. Send a PM to joe.I received my R6 with aluminum black last week and the sound is great!
But it seems that the power button is very loose and sometimes not work when I pressed it, is this the design of R6 or a flaw of my device? Does anyone has same situation as me?
Weird, I am #704 and no shipping notice. I’d think they would have gone out in order, but... I’m patiently waitingWow the train is in fast mode.
