HaVoC-28
- Aug 16, 2011
This is my personal experience...................
I find my DT880/600 ohm sound very good thru my Matrix M Stage: everything sounds very clean, tight and punchy, but a bland recording will sound bland. A great recording will sound great. The DT880s do not flatter bad recordings.
The Matrix M Stage has all the power I need. Keep in mind that headphones only require about 1-20 mWatts to sound loud.
I alos like the sound I get out of my La Figaro 336C (an OTL tube amp), it seems to smooth things out a bit.
Some guys like the sound of receivers, I'm not too sure why, I guess they like that vintage sound? I doubt it really has much to do with power. One thing about vintage receivers is that they normally have an output impedance of approx. 100 ohms on the headphone jack.
And another thing..................250 ohm, 600 ohm headphones all need a fair amount of voltage, you may not be getting enough voltage out of a soundcard.
So, vintage receivers...........they can usually deliver A LOT of voltage but usually have a high output impedance on the headphone jeack.
The DT880s:
I find them to be VERY comfortable, but just for a point of reference I have tried the Senn HD650 a couple of times, I find the they are too tight and have too much clamping force.
I find that AKG Q701s are very comfortable too.
Maybe I have a weird head, who knows? LOL![]()
you enjoy your DT-880-600 ohm on your m-stage , great ^^ many prise them with tube amps , but i really like my DT-880-600 on my C2.1 (wich i found better than my previous m-stage , wich still an excellent amp ), and beetween the m-stage and la figaro with dt-880 a preference for one or like both ?
i am reticent with tubes ,cause i tryed a LD MK3 with a K702 and for me it didn't work well , way better on my previous m-stage i see that you use a Q701 , does it work well with your la figaro ?
m-stage seams to work well with many headphones dt-880 , HD650 , K/Q/70X ...
