PurpleAngel
The JDS Atom or Schiit Magni 3 will drive 600-Ohm Beyer headphones.Is the JDS Labs Atom amp sufficient power for 600-Ohm models?
Do you already own the 600-Ohm beyerdynamic DT990 headphones?
Soundmagic HP151 closed headphones (32-Ohm), like an improved DT770.I got the Beyerdynamic DT770 Pro 80 ohm. It is not for me. Right off the bat, I was not impressed with sound quality. So I figured I will listen to it for couple days to decide. It is not expensive, so I thought it can be good value and backup headphones. After 2 days, I dislike the sound quality. And I have headache from the clamping force and ringing in my ears after listening to to the headphones. Returned.
I was debating between 32 ohm and 80 ohm version. I went with 80 ohm version as I thought it will provide the most dynamic and enjoyable sound. And also the velour ear pads.
On the other hand, I was concerned with getting enough volume on 80 ohm. It turned out as non-issue. On my iPhone XS Max, I'm can reach my max level at 60-70% volume. And sound seems to be slightly better on iPhone. On my MacBook Pro, I also have no issue with sound level, Again, at around 70% volume, I can reach my max level. I also have an amp. So I can go 50% on MBP and 60% on amp, I'm at very loud sound level.
Lows: Headphone is definitely bass heavy. And it is not very good bass. It is not horribly muddy, but it is also not tight. I just don't hear or feel the punch of the bass.
Mids: Vocal is a recess and thin. In some music (e.g. John Legend, Alicia Keys, Lauren Daigle in You Say), vocals sound fine. But in other tracks (e.g. Ingrid Michaelson, Natalie Merchant from 10,000 Maniacs), vocals sound extremely recessed and thin, either due to recording or just higher voices.
Highs: Highs are ok, but it doesn't have that sparkle. From what I read, I was expecting good highs, but I find the highs lacking, especially compared to heavy bass.
In summary, I find the sound dark and dull, as the bass dominates. So I dislike 80 ohm. I don't believe the minor difference with 32 ohm will change my mind.
Separate of instruments: Poor. Various instruments just got lost and muddled together.
Sound Stage: DT770 has wide-ish sound stage, probably because of U or V-shaped sound profile. I'm good with DT770 sound stage, but just not at the expense of weak mids (recess vocals).
Comfort: Velour ear pads are super comfortable, so no issues on my ears, particularly with me wearing eyeglasses. But there is strong clamping force. So after 1-2 hours, my upper jaw and temple are uncomfortable and I have a slight headache.
It's basically open, but less so than the DT990 which has a more V-shaped response.So is there actually anything to the term "semi-open" Beyer uses for the DT880 or is it basically open?
Sorry to dig up and old thread. I saw a local set of DT 990 for a really cheap price and the headband and text look exactly like this! So I was trying to figure out the age of it. Apparently the guy selling use to work at the local Beyerdynamic here in my countryMy hint was the older chassis on this one. They are definitely NOT a warm headphone, right on the cusp of being too bright, but nowhere near as painful as the 250 ohm version that I've owned before. I cleaned these up a bit after buying it used and immediately ordered new EDT770Vs. Good as new. This one is about 10 years old, so 2009ish according to the original owner, for reference.
