I did. Bottlehead Mainline is my main amp. 325x are more dry sound vs creamy Hemps.
When tried on Lyr OG there was too much noise because of low impedance.
On Mojo2 I didn’t like 325x, it was very dry sound.
I guess they have very similar drivers and the difference comes from the cup’s material.
I love the 325x on mojo2 probably for me one of the best I have heard them, better transients better layering and toned the bass down a little compared to other sources I own.... each to there own though and i do lean more to solid state than tube anyway.
Seriously was considering trying a mojo amp but don’t like having all the extra adapters for my phone of choice (iphone). So I am going to wait until the iPhone goes all in on usb-c when the iphone 15 drops then my options will be way open to what I want to do.
Unless the Mojo 2 is mfi-certified by Apple even an iPhone with a USB-C jack won't help you, you'd still need the "camera adapter" so the iPhone would recognize the Mojo2.
Like I said that is why I am skipping the mojo because of the adapters… once the usb-c port maybe it will be easier for compatibility with a wider range of options just gotta add the certification… I hope to see good things with the usb c port
Very impressed with mojo2 , I owned original and it's definitely better ...been using it daily since I got it but my cayin n6ii ro1 is just as good in a different way ..
Hi Guys I can confirm all of my lightning to usbc and usbc to micro work with Chord Mojo 2.
Also work with every other usbc dongle dac I have plugged them into.
These all work with Mojo OG
Mojo 2 Hugo OG and Hugo 2.
The adapters are ddhifi,Fiio and Hidizs.
Picture of the Hidizs cable from iPad to the Questyle M15.
I use the right angle ddhi lightning to usbc from phone to M15.
I sold my Mojo 2 for the M15 as it fitted my use case better.
No it doesn’t sound better than the Mojo 2 but it’s still very good.
Got offered on a deal that I just couldn't say no to ..... I have time to add to my shipibo order so which gimbals and locks should I get to go with the new additions? Probably swap out the band to a black one.
