Awesome headphones!Ended up with a pair of the GH2, added a pair of g cushions for comfort and I am satisfied for what I wanted.
Grado Fan Club!
- Thread starter Vikingatheart
- Tags
- 1000hours burn-in minimum 1000hours hearing damage minimum dynamat grado grado hf3 grado-gs1000 grado-head-fi-series-hf-2-headphones grado-igrado-black grado-professional-series-ps500-headphones grado-rs1i-reference-series-headphones grado-sr-80 grado-sr125i-headphones grado-sr225i-headphones grado-sr325is-headphones grado-sr80i-headphones grado-statement-series-gs1000i-headphones nhoord nhoord red v2
If you can, try the RS-1x with G-cushions…
What changes did you notice with G-cushion? I just bought RS1x, but my ears hit the grills with the stock pads. I've never had this happen with any other Grados before.
G-cushions would help, but it would be a $50 gamble if the sound changes too much.
funkymartyn
I have a few of these cases. £6.99 . They're good. I use them for my Sr60, Sr125e, Sr225e, and Rs2e with normal L Cush pads. I have the larger grado big square case for my PS 1000, as the G pads need room.Ebay
Cheap and good. I buy them from GB
I’m interested on how the Joseph Grado Signature HPA-1 compares to the Gilmore Lite km2 while driving grados. I have never heard one of the Grado amps so I’m curious about what kind of amp Grado has in mind for their headphones.Sorry for the super long delay, I somehow missed your post & question. I just wanted to confirm which of the Grado amps you wanted to compare to the Gilmore Lite mk2?
Thanks,
Holiday Greetings,
Joe G.
Corvin25
- Aug 5, 2009
Hello. VERY infrequent poster here. Not really an "expert," but I do love good-sounding music.
I found some old headphones that I hadn't worn in years, An old SR80 and SR325i. I was thinking of getting them repaired by a Grado-certified technician, since they both are in dire need of repairs, like new cables and headbands. Currently using a Sennheiser HD599(which is amazing), but I just like to switch it up sometimes, spread the "abuse" between sets. And I remember being blown away by the sound quality way back when, so...
I'm just wondering if it's worth it to get these old Grados repaired. I know the SR325 is up to the "X" drivers now, meaning my 325i is more than a decade out of date. Is it still worth getting them fixed? Or is the sound difference negligible?
And lastly, are there any recommended alternative earpads to Grado's official ones? I can't say I'm a fan of their official earpads since they really hurt my ears and they crumble like cookies after a year or two. I'm eyeing some Geekria Grado pads on Amazon.
Hope to hear from someone soon, thanks!
Happy 11th birthday dear 'Grado Fan Club!'-thread, started Dec 29th 2010!
I've been away for a while. I did some searching here but didn't find a clear answer, so maybe someone could give me a short run-down of what the differences between the RS1e/RS2e and the RS1x/RS2x are?
Luckyleo
There are things you can do regarding fit while still using stock pads. When I received the RS1x I felt like the clamping power was uncomfortable, and that my ears sometimes hit the grills too often. I did 2 things. I slightly and carefully put pressure on the headband flexing it out. I never bent it per se. The other thing I did was remember that Grado themselves suggests wearing the cups slightly lower than you would normally for either over ear, or on ear headphones. When worn that way they seem too low, but are actually much more comfortable AND it seems to have a positive impact on sound stage and general overall tonal balance throughout the sound spectrum.What changes did you notice with G-cushion? I just bought RS1x, but my ears hit the grills with the stock pads. I've never had this happen with any other Grados before.
I've tried these RS1x's as well as the RS1e's with G pads and notice a definite difference in sound (and a big improvement in comfort prior to making the adjustments mentioned above). Sound stage is bigger with the g pads, but the sound just doesn't seem as "smooth" and sublime to me. I prefer the stock pads.
As always, my opinions only. YMMV.
Good Luck!
I recently bought the GS1000e's and having spent more time with them I have a few problems.
Like another member had mentioned, the bass is somehow off/weird. To me, it sort of exists in a specific region, rather than have extension and depth.
The cable is entirely crap and way to unwieldy, especially when having to connect the 3.5mm adaptor cable and using with a dongle. I would modify them but I really don't want to void warranty and I'm still within my return period.
My question is... is there another headphone out there that has that incredible soundstage & imaging, detail & resolution, with some of that magical Grado sound (or even a more neutral but still engaging sound) that has some more natural and extensive bass?
I've been looking at the Audio Technica ATH-R70X, Beyerdynamic DT1990 Pro, Shure SRH1540's.
My plan is to buy one of the above (or any other recommendation) and buy a lower-end Grado for fun.
Just taken delivery of the SR80x - my first Grado. I'm sufficiently impressed for the price and the sound signature is spot on for me!
Where would you guys recommend I go next for wider staging / better dynamic range but a similar tuning with a budget of <£500?
