ruinedx
- Sep 11, 2016
All of what you said is only true if the same driver is used in both enclosures and there is no attempt to tune the driver and specifically design the headphone innards for the enclosure material type. The driver itself and other properties of the headphone can be tuned to accommodate whatever material is being used to mount the driver in.Totally disagree with this. If the HD800s was made of wood, it would sound like a TOTALLY different headphone. Same with any of the expensive headphones you've listed. Just a top flight headphone doesn't use wood, doesn't mean that wood doesn't change the sound.
Sennheiser, Focal, and others don't use wood because wood won't get them the sound that they want to achieve. If a violin was made out of plastic or carbon fiber, it would have a completely different sound signature and tonality. Same with headphones. The cabinet, or sound chamber that the driver resonates in has a resonant frequency. Wood has a different resonant characteristic than any plastic and vice versa. To say that wood is simply for aesthetic purposes is completely ignorant statement.
Wood is primarily for aesthetic purposes in headphones, yes. It's not that the wood doesn't impact the sound at all, its that a similar sound as a given wood headphone can be achieved via other means with no wood at all - hence using wood in the first place is an aesthetic choice.
