ruinedx
- Sep 11, 2016
Will look like crap thodremel tool is your friend
Here is a pic of the issue. Top is the gradio 3.5mm plug. Bottom is the typical 3.5mm plug you get designed these days for mobile devices with a case. Note the clearance difference at the base of the plug, allowing the bottom plug to fit without issue in pretty much any mobile device in case. This is a major oversight by Grado IMO, when 3.5mm is going to be used 99% of the time in a mobile device with a case.
