Grado Fan Club!
Dec 21, 2020 at 2:32 AM Post #44,431 of 65,695
Hemp is not weed though😉
Just tell em it’s one of the oldest and most useful plants out there used for rope, paper and all kinds of medicinal purposes. There is a reason it is sacred in many parts of the world.
Dec 21, 2020 at 7:58 AM Post #44,433 of 65,695
So far, the GS3k sounds like a very fun enjoyable headphone. Best treble of all the grados I've tried (SR60, SR325i, MS2i). It's a wonder how it can have so much treble and detail without getting into harshness or sibilance.
Central imaging is very strong and sounds even more forward than my Utopia. I switch back and forth on the same songs and the presentation is almost on opposite ends.
Bass I hope will improve with use. Doesn't extend as low as my other headphones and lesser in amount too, but very tight and fast and has decent detail.
Dec 21, 2020 at 10:51 AM Post #44,434 of 65,695
For the full bass of the GS3000e you need at least 100 hours burn-in time. Maybe after that you can compare it with your Abyss 1266? That would really interest me. thanks.
Dec 21, 2020 at 12:02 PM Post #44,435 of 65,695
Hemps are inbound for Tuesday. Very excited, been away from home for quite some time due to the ongoing human malware and have been missing spending time with music.
One quick question: Hemp owners, is it possible to pop off the middle of the cup branding with the leaf in a way that it can be cleanly reattached? They have a cool look, and more importantly a very unique sound (which is why I chose them over others), but if I can temporarily detach that branding while I'm out here I can avoid raising some eyebrows with some of the family I've been hunkered down with.
Hope that isn't too sacreligious, but let's just say while you can choose your friends, you definitely can't choose family 😅. Either way ill be sneaking away to spend some serious time listening.
They're just glued on. Should be able to remove them if you try but honestly, I personally wouldn't risk damaging them. Would likely take some effort and could change the sound of them a bit.
Dec 21, 2020 at 2:11 PM Post #44,436 of 65,695
[QUOTE = "Roasty, publicación: 16051582, miembro: 23593"]
Hasta ahora, el GS3k suena como un auricular muy divertido y agradable. El mejor agudo de todos los grados que he probado (SR60, SR325i, MS2i). Es una maravilla cómo puede tener tantos agudos y detalles sin entrar en aspereza o sibilancia.
La imagen central es muy fuerte y suena incluso más avanzada que mi utopía. Cambio de un lado a otro en las mismas canciones y la presentación es casi en extremos opuestos.
Bajo espero que mejore con el uso. No se extiende tan bajo como mis otros auriculares y también en menor cantidad, pero es muy ajustado y rápido y tiene un detalle decente.
[/CITAR]
Hola
¿Podrías compararlo con gh2?
Cheers
Dec 21, 2020 at 4:16 PM Post #44,439 of 65,695
Dec 21, 2020 at 4:33 PM Post #44,440 of 65,695
Gh2's here for £399. I bought a pair from them last week. Free next day delivery. Couldn't be happier with them . Absolute steal at this price! https://homeavdirect.co.uk/headphones/headphones-on-ear-headphones?manufacturer=80
That's a great deal mate , good spot. I picked up a nice deal couple of weeks ago from a audio shop seller on ebay too the Rs2e £385. Then picked up the geekira LL, L , and G pads from amazon. All worth a try for comfort , etc. ..not bad prices really. The LL. Are defo worth a go £11. Comfy , and like a larger softer sennheiser 414 yellow pad.
Dec 21, 2020 at 4:39 PM Post #44,441 of 65,695
Very happy with these G pads but I'll take a look at the LL you mention, thanks
Dec 21, 2020 at 6:30 PM Post #44,442 of 65,695
Dec 21, 2020 at 6:31 PM Post #44,443 of 65,695
Dec 21, 2020 at 6:37 PM Post #44,444 of 65,695
Sorry if this has been asked before, but what hard carry case do you guys know can fit the gs3000e nicely?
*edit nevermind just found a nice one from 4ourears
Dec 22, 2020 at 3:59 AM Post #44,445 of 65,695
