ruinedx
- Sep 11, 2016
For #1, their mechanism is lightweight. I disagree that their plastic rodblock is "cheap". To me, it's a good weight-saving measure.
They look cheap and probably are cheap. In reviews or first impressions this remark is often made (in fact someone who bought one last week said this), so I am definitely not the only one.
The amount of weight saved vs aluminum is probably like 5% of the overall headphone weight (if that) and not something that would be noticable. On the other hand the way it looks is very noticable. Doesn't need to be a solid lead block, simply a few mm thick aluminum shell will do.
Going to metal rodblocks is only for aesthetics and will add weight. Admittedly, this really only matters for the >300g headphones: SR325e, PS series, and GS3000e.
Metal will be a little more durable if they were dropped or stepped on I would think. But yes, aesthetics. You know, which is also a lot of the reason someone would buy a headphone with cocobolo earcups. To have exotic hardwood earcups and then have the rest of the headphone look like a budget headphone is plain weird and an obvious aesthetic mismatch. That might be fine on the cheaper grados but anything Statement series+ should be built better.
It may be classic grado, but that doesn't mean it's a good idea when your competitors are kicking your butt in this department (overall fit and finish) in $1000+. ZMF basically took the Grado headband design and made it look nice, Grado should be competitive and improve their aesthetics as well on their statement+ series.
For #2, the cable can be severed below the Y split, and an aftermarket cable can be installed from that.
Why should anyone have to splice in an aftermarket cable on a $1000+ headphone ? That is a bit of a joke, if you ask me. It should be user swappable at the earcup like everyone else does.
Those issues are trivial to what I feel are the two main turnoffs: the headphones can't be easily disassembled, and that I've experienced questionable driver matching >1khz.
I heartily disagree. I guarantee a massive amount more people will notice the aesthetic mismatch and inability to swap cables than the amount of people that will try to disassemble the headphone or verify driver frequency response.
