My God, look at how they don't fit his ears AT ALL!!! Almost the entire bud is sticking out of his ear :O :O
No wonder he hasn't enough bass, and they are moving around when he is jogging...
Maybe this is why some of you don't like them? You have the same abysmal fit?!?
WIth me these are tucked tight in place, pretty deep inside, with no movement at all!
Edit: I can see that fit could be a problem with the form factor of the Tevi, especially compared with the "snug" Anbes 359. I can actually sleep on the side with the 359s, without noticing them.
Well to be fair, The Tevi and T5 stick out of my ears if I don't turn them horizontally They also fit further out when I use my M/S spiral dots. You don't have to have an earbud shoved all the way in your canal to get a good seal. Like I've mentioned, I've used the same tips on both. If I were to give the bass of the Tevi a number it would be 3-4, compared to the bass of the T5 would be a 6-7. and the bass of the L2pro a 9. interestingly enough the L2pro does a really good job handling different bass frequencies so its' not all muddied and boomy. @BigZ12 you should check them out, i'd love to hear your thoughts.
