The
TREBLAB arrived and I've been testing it for the past hour or so. As far as size, the case is quite compact and roughly half the size of the MTW.
PROS
- Comfortable. Compact. Fit securely.
- Bass is nice and deep with slightly forward mids and rolled off highs. Definitely a fun, warm tuning that works well for workouts. I would
not describe it as "muffled". The drivers sound like they're a quality set and the sound is a specific result of tuning.
- Case and earbuds feel well build and fabrication is nice. No rough edges. Buttons click nicely and have a consistent click on each side (one side is not softer than the other).
- No driver flex.
- AAC support.
CONS
- Not for those that enjoy a crispy, bright sound signature.
- No aptX.
- Micro USB.
- Despite what the description indicates, there are no volume controls. The manual does not show any multi-function button presses for volume. A little disappointed here, so I sent the seller an email informing them this issue. Hopefully they update it so nobody else has to discover this surprise.
PENDING
- Still need to test out call quality.
If the call quality is good, I could recommend these at $49 for those that enjoy a warm, bass-forward signature, even with the lack of volume control. I'm actually enjoying them quite a bit, think they look very sleek, and are very portable. Aside from the Tiso i4,
there is another pair that looks exactly the same for $20 cheaper, but it has an IPX5 rating vs the TREBLAB's IPX6. As far as the SoC, I'm not sure what each use.
