bubsdaddy
- Apr 21, 2003
Get both and be done.
Don't mislead him. We are never done.
The Jabra 65t have "good" SQ, but many of the top Chi-Fi are better (Anbes 359, MPOW T5). The Soul sounds better than the Jabra 65t IMHO. The Jabra are a little "boring" and have a narrow EQ range. "Vanilla" sound.I just don't trust Jabra with prioritizing SQ, unless it's for phone calls. Maybe I'm wrong...
Regarding the JBL Reflect Flow - never even heard of them. Yeah, I'm reading that their ambient mode is kind of a hack since it basically just turns down the music.
Would you recommend your MTW if they were closer to $150? Reviews are mixed...
Not a fan of JBL. They only roll with SBC in most of their cheesy wireless stuff, that's also overpriced.
The Galaxy buds are good, very clean/clear sound, AAC, responsive touch controls, and have a solid feature set, however, they're bass light and do not EQ well in that department. They'll begin to distort when you try to ramp up the bass. If you enjoy bass, I would not recommend. If you don't need bass, they are a good choice, however...
...if you can get the MTW for around $150, that's probably the best solution for you. Great sound (in that second tier behind the MW07), ambient, decent calls, satisfactory touch controls (a little slow response time, so takes a bit to get used to), good fit for most, AAC, aptX-LL. As long as you plug the case in every 2 days or so, you'll be fine. It's the best balance of features/sound.
CONGRATS!!! WHat did you get?
My experience with that program has been ... well .. MIXED ... I 'won' rather quickly a pair of cheap ass i7 airpod clones ... they took forever to arrive, were not the advertized color and from 'no box, looks used' I guess they sent me an old showroom model
Please please share with me if / how you managed to do that crazy review 'homework' ... this is very different from the usual review writing ... I tried like 5 times and in the end the AI always told me that I was not responding to the suggested points correctly
I have the suspicion that as long your freebie is traveling and until you write your review you cannot get another freebie ...
for more details and mental review writing prep, see my post from Aug 4
EDIT: I just spent another hour on this and lo-and-behold ... i finally got passed that pesky AI and now it sits in 'waiting to be approved' ... it appears that the kicker was that you seemingly have to add a photo to each single category, no matter how shoddy it might be. Of course I was thrown off by the message telling me that I failed following 'the tips' ...
Not sure what you mean by "crazy review homework"?
If you buy from Amazon US, then returns if they don't work for you, wont be an issue (unless you're a chronic returner). They're the most budget friendly earbuds with good sound/ambient that I've found. The ambient mode BTW is good and has great pickup. It does, however, pick up the wind noise, so if your outdoors, that could be an issue.Based on what TK33 said, it looks like the battery life for the MTW wouldn't work for me. Plus, at ~$300 it's currently way over what I'd like to spend right now.
Leaning towards the ST-XS2's at this point.
I have a feeling that Sony is going to release an active/sport variant of their WF-1000XM3... and I'm sure it won't be cheap.
Yeah, I have...I'm a recovering basshead.Try some wider tips on the Galaxy Buds. The bass is there, it's just hidden by the stock tips!
By multi point connections do you mean the chipsets ability to connect to multiple devices at once or are you talking about True Wireless Stereo Plus etc?Hello,
i'm still looking for some TWS mit multipoint connections - without any success (beside the high latency Jabras).
It seems that the new Qualcomm-Series (QCC300X,QCC30XX,QCC51XX) don't support multipoint connections. There is no information in the datasheets. The datasheet for the older CSR8645 on the other hand says: "A2DP multipoint support: 2 A2DP sources". Did they really drop something highly useful like multipoint connections with the new chip series?!
Is this the "Air" or another rebrand? Does it have obnoxious voice messages for everything? I found thr air more subdued and congested compared to Coolhere UFO, also hisses on the left bud a bit (nothing like Jabra though). Unless I removed the filter, the right bud sounded rolled off in the treble, but taking it off made it too sibilant compared to the right one. It took some testing out the ratio of foam size and density to balance the mids and treble. With the varied impressions here, some saying the Air sounds the same as legit Anbes, but others saying there are worse sounding units, I'm not sure what to think. Aside from Earfun Free I've yet to get a budget TWS with well-balanced channels.As with the set that another member got here, mine has no volume control. The sound quality is good, can be sibilant at at times due to the brighter mids-highs. Soundstage is almost holographic, very good wide sense of space.
You will, once you get to it (also, you obviously did not follow the link I posted, to my previous post)
Yes mine shows up as Air in the bluetooth listing. I don't hear hiss on mine though. The sound is quite well articulated and open, not congested. The nozzle is oval shaped, and there's a lady speaking English "reverse" "forward" "primary" "secondary" which I find quite useful.Is this the "Air" or another rebrand? Does it have obnoxious voice messages for everything? I found thr air more subdued and congested compared to Coolhere UFO, also hisses on the left bud a bit (nothing like Jabra though). Unless I removed the filter, the right bud sounded rolled off in the treble, but taking it off made it too sibilant compared to the right one. It took some testing out the ratio of foam size and density to balance the mids and treble. With the varied impressions here, some saying the Air sounds the same as legit Anbes, but others saying there are worse sounding units, I'm not sure what to think. Aside from Earfun Free I've yet to get a budget TWS with well-balanced channels.
If Kissral dies out as well Letscom and Yineme is probably your safest bet. Monster has Airlinks HD if you want different aesthetics for 100$... I'm curious about the DOGO BE30E, with redesigned housings. Haven't seen a seller listing yet.
