dweaver
- Dec 23, 2008
I was reading up on the InZone model and the driver is supposed to be the same one used in the WF-1000XM5...They seem like XM3's in White.
I think they are a little too “Harmon”. But they definitely aren’t bad.Like to admit it or kit the Akg n400 is still as banging as any other
What’s your music and do you speak Japanese? I looked up the Aviot app and I’d need it translated… just curious about the music as that might impact what earphones you like - if a lot of bright female voicesWhile I'm enjoying my MTB03 now, I still rank the Aviot TE-Z1pnk as the absolute best in the SQ department amongst TWS released up till now in terms of balance, soundstage, bass rumble and high-extension, together with great functionality and very nice ANC. Soundwise the MTB03 is the more natural and relax listen with slightly better coherence (single driver afterall), while the Aviot is more technical and revealing. Both got excellent soundstage for a TWS and impactful yet not distracting bass.
can you post some pictures from the Montblanc app? I want to see what options there are for ANC and EQ respectfully. Thanks!Want to add that the Montblanc offers one of the, if not THE, most satisfying natural soundstaging capabilities out of all TWS I have tried/bought. Balanced, natural and transparent sounding, nothing tries to steal the focus from the whole.
With all that said, this sort of sound signature might not jump at you at first listen, so if you have a MB boutique near you, do set aside some time and do a more extensive demo with different genres. Pretty certain you won't regret it.
It has the XM5 dynamic driver X so it can't be the XM3. XM3 is a 6mm not the 8.4mm. Smaller and a better shape even though there is a resemblance if looking quick.The Sonys could be interesting as video call/gaming earbuds...!![]()
Yep, but keep in mind they aren’t the same as the previous Liberty 4. Different driver (one 11 mm, new release), the original has two drivers per unit. It was called the Liberty 4 SE. Typical TWS mambo jumbo, to confuse everyone. It’s why the cheaper entry price. $99 vs $149.OK, so these Soundcore Liberty 4 NC are really nice and at $80CAD an insanely good deal...
Major fun factor sound, not for purist but who cares... LOL.
Tips appear to be pretty proprietary fortunately they fit well.
Thanks - music matters as I find my Sony DAP works better than my Mojo2 in some cases and I add tubes depending on my IEMs. Svanar TWS can be a little bright at times, but super with classical music as one example. Thanks for the Montblanc description. What’s the range of the EQ? Does it actually EQ the full range or is it truncated? Does it go from 20 to 20,000 or 200 to 10,000? Noble seems to be one of the few that would allow me to really fine tuneI listen to everything really from classical to Pop/rock, including lots of J-pop and J-rock. Bright female voices or not doesn't matter that much really, the best iems for that actually tunes DOWN the brightness to make it sound good. Japanese songs are instead known for its complexity in arrangements, so anything does good for Japanese music should do well in other genres. My test tracks must also include classical orchestral music - the only iems I can stand are those which can make every instrument sounds RIGHT (iems that can do that are way rarer than you might think TBH)
Options for ANC on the MTB03: Travel, Office, Sports mode. Plus a "live mode" which means transparency mode, and a standard mode which turns off ANC altogether. EQ is pretty standard stuff, with a few presets.
They look a lot like the Earfun Air Pro 2/3 !OK, so these Soundcore Liberty 4 NC are really nice and at $80CAD an insanely good deal...
