Oct 13, 2023 at 8:33 AM Post #57,481 of 69,984
Well, pleasant surprise -- they arrived with the postman not Amazon.
First up -- for £99 these are lovely. I'd pitch them against the MTW3's interm of overal "out of the box" sound.
ANC is very strong. I'd say easily on par with DPP/MTW3 with the Bose QCU being another step-up
Was able to crank up the airplane noise video above pretty high and while i could still hear it 55-65% volume on the buds was pleasant hearing volume. They are capable of getting VERY loud. I'm listening at maybe 65-70% but i cannot turn these above maybe 90% before it's unbearable. I didn't want to put them to 100
The buds come in the now obligatory plastic free packaging.
Items included:
  • User Guide
  • 3x sets of tips (very tall ones)
  • 1x no ridge wings (normal fins fitted)
  • USB C cable
The charging case is small and very pocket friendly. No wireless charging (but since Bose felt it appropriate to skip this on their £300 buds i can forgive Samsung for this)
Just a small light on front to indicate charge status.
The case is glossy/smooth white (even though buds are graphite colour), i thought i'd got the wrong buds when i saw case :)
The included ear-tips are meshed and tall. The stem on the buds is short with a small retention lip but circular.
You only get the option of the retention fins as either yes or no. The replacement option in the case is smooth with no raised parts.
Typical 3 sizes of ear tips in grey silicone. I found them too tall for me though and immediately replaced with Spinfit CP1025's for TWS which are my go-to tips as they make the buds size much more comfortably in my ears (both canals and concha gets much less fatigue)
Pairing/Sync
I have a Samsung S23 so the buds are much more deeply integrated into the phone OS than for any other device.
Opening up the case immediately does an Apple-esque popup showing a picture of the buds and a simple connect/cancel button.
It then downloaded the plug-in for the buds to integrate fully. You have 3 options to see various levels of info/controls:
1. Home screen widget gives you battery level of the buds and 2 buttons to toggle ANC/Ambient/off and a second button to enable/disable the touch controls on the buds
2. Bluetooth section gives battery life, options to divert calls/audio and enable or disable multipoint but this seems tied to Samsung devices. The page also gives ANC controls and a button to open Samsung Wearable App
3. Samsung Wearable gives you the whole entire control suite
In the Wearables app you have options to customise the touch controls but only enable or disable predefined functions -- cannot change what the taps do
You get find-my-buds option and then settings.
In that you get EQ (select from pre-defined options no custom EQ), an earbuds fit-test (simple tone thing), then ususal smart assistant and other basic options
There is a labs gaming mode too available which i assume lowers latency
Ok - with a quick tip reroll, for me the buds are some of the most comfortable i've got with a caveat. They sit nestled nicely and don't put any pressure on anywhere.
They don't feel quite as secure as my MTW3, they do with stock tips but that ends up pressuring my concha too much. But i know i'm really hard to sort out for some reason with my ears
Onto the sound...
This is where they're a surprise. Out of the box they're really nice. I'd put them very very close to the MTW3's.
In terms of bass i enjoy the depth and feeling of a good sub-bass even if it's not particularly elevated, just like the extension into sub-bass.
I would rank the 4 buds i've listened to recently in this order:
Bose QCU 4th
MTW3 tied 3rd
Samsung Buds FE 2nd
Denon Perl Pro 1st (they just have bass for days)
One thing though they don't have any background hiss present when music isn't playing. This is definitely something the MTW3 have.
But for the rest of the spectrum i'd probably put them all very similar bracket. Some have slight benefits here and there but it's hard to pinpoint.
I'd say the one thing the Samsung Buds lack is EQ possibility since you simply have the "bass boost", "Treble", "Vocals", "Dynamic" type presets but you cannot tweak an EQ, nor do they do any kind of personal tuning.
So that puts them in last place for that but the default sound isn't far off how i like it anyway. The dynamic option gives the classic V type of adjustment lifting the bass and treble with a small dip at 2-4k but overall that's the "fun mode" option.
Buds touch feedback - they do have beep audio signal on touch press but where with the MTW3/DPP it's a live immediate response to each touch, the Samsung beeps the number of times it thought you pressed after you stop pressing. So just after your double tap you get a very light double-beep.
Still better than Bose which has no beep feedback which i find irritating.
Codec is hard to know -- they support AAC/SBC but the SSC (Samsung Seamless Codec) which can support 24/96 -- but nowhere can i see in the app / settings where i can confirm my S23 is using that with these except when i checked in Developer Options i could see it was the active codec.
The signal strength though is RIGHT up there. With my phone on my desk in my office i could go to the other end of the house (back of kitchen) and it didn't even flicker in sound. Most buds start to break up around the sink (when i'm getting myself a drink i tend to have my buds in and often it starts to give an odd drop with most)
I think we're really in a rapidly evolving time with this stuff but it feels like we're creeping towards that point of diminishing returns.
The quality you can get for £99 is staggering. Given i've tried the DPP's twice, the MTW3 (own now) and the Bose QCU
I cannot see the DPP's or Bose being worth 3x the price. Yes they all have their own twist on things, with DPP's Nura acquired tech, Bose ANC prowess etc
But the Bose are not worth the money for me -- the "Ultra" moniker has been used too soon by them to justify it as more than a QC2.5 and for me the music side was lacking.
DPP's are nice (actually bought them again to give them another chance) and if you want screaming bass then yeah -- they can pack a huge punch. The MTW3's are the premium "come good" option with their new personalised sound option which seems to have transformed them.
I think the issue with "premium" TWS is longevity. The codec's are not unified yet, the tech is getting mature but it is not yet consistent, especially with non-apple products on iPhone still being limited to AAC.
Even on Android where LDAC/AptX Adaptive is available most phones still don't have it.
So paying so much for a battery depedent item which has non-user service construction means that premium has to be something amazing given a shorter lifespan.
At least wired IEM's can be made wireless, or can have a life ranging to many years without issues.
Anyway -- enjoy your music
20231013_112257.jpg20231013_112409.jpg20231013_112448.jpg20231013_114749.jpg20231013_114846.jpg20231013_115857.jpg20231013_115904.jpg20231013_122512.jpg20231013_122529.jpg
Oct 13, 2023 at 11:49 AM Post #57,483 of 69,984
Grabbed the pixel buds pro with my order of the pixel 8 pro with free pixel watch 2. Have been on pixel stuff for years now, but only the phone, never anything else. I thought those other products looked good this generation so I got them. Well the watch 2 was free with the preorder of the 8 pro, but I was going to sell it, it's nice though. Just could be a few mm larger of a case.
These little pixel buds pro are fun. The form factor is amazingly small, both the case and the buds. They sound fun and more than decent enough for some outings. Love the size though, can stick them in that tiny pocket that most pants have right above the front right pocket. I'm actually headed to the google store in Chelsea to pick up a different colored watch band for the watch2, and all I'm gonna take is the buds pro cause the case is so small.
So far ANC is decent, transparency mode seems good, the controls are pretty solid. Haven't tested out call quality but a recent firmware upgrade for them improved a bunch of things significantly, including wideband bluetooth for calls.
I honestly was pretty hesitant to get them too but I am pleasantly surprised. Been listening to the Volur via the BTR7 or iFi go pods, or the Mystique, so wanted to add a newer pair that had more of the TWS on the go techy features, sub 200, that weren't big. Glad I gave them a shot.
Oct 13, 2023 at 12:27 PM Post #57,484 of 69,984
Items included:
  • User Guide
  • USB C cable
Pairing/Sync
Onto the sound...
Bose QCU 4th
MTW3 tied 3rd
Samsung Buds FE 2nd
Thanks for sharing. I'd have to agree that it's a bit hard to justify the $250+ TWS, even 200€ like the Jabra 10s where recently discounted at on Amazon. Have you looked into the Liberty 4 NC that seem to have a more powerful ANC than the FE's. I might give them a try to replace my ageing EarFun Air Pro 2 that lack multipoint and are rather useless for conversations.
It's hard to find "listen to it for yourself" reviews but here's one where the L4NC are pretty much on par with the ARPro 2
Oct 13, 2023 at 1:41 PM Post #57,487 of 69,984
They look a lot like the Earfun Air Pro 2/3 !
How would you compare them to the Jabra 10 in terms of SQ and ANC ?
ANC is agressive on the Liberty 4 making it not as pleasant in quiet conditions as I found out this morning as I could hear/feel the hiss. But since its quiet why would I use ANC... I turned it off and then the passive isolation was more than enough.
ANC on the Jabra Elite 10 is less invasive feeling and works in all noise conditions well aside from Wind which is not just a sound but physically moving air. In wind if its hard enough you can switch the mode to Hear Through and after a few second the device will automatically block the wind and be very effective. But if the wind is not strong enough or gusting the TWS may just go back into normal Hear Through mode which would then get noisy...
The Liberty 4 NC actually just has a Wind option in the app to handle wind. Not sure how well it works yet but I like having a setting like that, the MTW3 has a similar option. I do suspect wind will be addressed in some fashion with an update on the Jabra Elite 10. But for now its ability to handle wind is automated and consequently a bit hit and miss...
One other point. The Liberty 4 NC is a typical stem style design and is as comfy as the Elite 10 but has a typical passive seal making the ear feel stuffed to a certain degree. The Elite 10 on the other hand is actually designed to be more open, they consequently rely on ANC more as the passive isolation is mediocre at best. But they feel really nice in ear because of that lack of feeling stuffed.
Sound...
Hmmm, the best way to describe sound betwen these is the Jabra Elite 10 is a Dad stereo while the Liberty 4 NC is the kids sound system... the first is designed to be more accurate and allow you to peer into the soundscape, the second is just about having fun!!!! As someone who grew up loving the kids sound and then growing into that other realm I LOVE BOTH! If I want to deep dive into some old prog rock and hear the instruments wizzing around my ears I can grab the Elite 10. If I want to mash some old fashioned ACDC I can grab the Liberty 4 and just rock out!!!
In more technical terms, the Liberty 4 is bass heavy and leans into a warmer signature but still has good strength in the treble (a V/U shaped sound). The Jabra Elite 10 on the other hand has tamer bass (but not to tame at least in my opinion) with a more balance midrange and treble. Its leaner sounding making it very very airy, helping it have a nice big sound stage with great 3D positioning.
Another way of thinking about the 2 would be equating the Jabra Elite 10 with the sound track from Blade Runner and the Liberty 4 NC with the sound track from Blade Runner 2049. The first movie the music drew you into the story. The second movie the bombarded you during the story...
BTW I saw someone suggesting the Libert 4 NC make it hard to justify the bigger ticket TWS like Sennheiser, Sony, etc. Have to say I agree, these darn things sound good and have pretty much every feature a person needs in a TWS thrown into them... It crazy how much tech they stuffed into such a cheap device and then make them sound good on top! CRAZY...
Oct 13, 2023 at 2:28 PM Post #57,489 of 69,984
Windows was supposed to add LE (needs to be at least BT 5.2) support back around the same time they added AAC and it already does support BT 5.3 if your hardware does and support is there for BT 5.4 (Intel AX210 is BT 5.3).
Oct 13, 2023 at 2:53 PM Post #57,490 of 69,984
Do anyone know something about the release of the creative - xMEMS tws ?
Yeah I tried them at Creative's creators press day in London last week. They've got two models scheduled for release towards the end of November - Aurvana Ace and Aurvana Ace 2. Both have Qualcomm chipsets, the latter support AptX lossless and Snapdragon Sound. Both support LE/LC3 and Creative talked about the existing products on the market and how they haven't really demonstrated the capabilities of either LC3 or LE at all. Creative have their range of dongles as well, so they're hoping this will push these technologies forward.
The Aurvana Ace 2 in particular sounded really nice, and I believe the price will be quite competitive. Their CEO was there and he made a big thing about giving more people the opportunity to try these new technologies. I can't share much more than that really as per what helmutcheese said - no NDA but it was a very small forum (only five of us, one was one of the big review sites, the others were Twitch affiliates) so I should probably err on the side of caution with what I say!
Oct 13, 2023 at 3:41 PM Post #57,491 of 69,984
What's with Ace and Ace 2? Something wrong with the Pro and Plus they already use? :) I mean 2 is for the tweak model that come down the road a bit like the Gemini 2 etc. not for models released at the same time.
Oct 13, 2023 at 4:34 PM Post #57,492 of 69,984
Sound...
Thanks for sharing your thoughts in detail, that makes me want to try them ! I agree that the Jabra 10 are very comfortable although they tend to move around and "stick out" after a while and that's rather annoying. The lack of decent passive isolation is always going to be a problem though because ANC can't make up for some frequencies that come through as I found the other day in the train (guy snoring nearby while I was watching a movie) or the the noise of traffic on a wet road. I admit that I like their SQ though with a lot of detail coming through. Going back to the EarFuns is a bit difficult after that.
Oct 13, 2023 at 6:55 PM Post #57,493 of 69,984
Items included:
  • User Guide
  • USB C cable
Pairing/Sync
Onto the sound...
Bose QCU 4th
MTW3 tied 3rd
Samsung Buds FE 2nd
Thank you for all the details
Oct 13, 2023 at 6:57 PM Post #57,494 of 69,984
I am lucky, the Elite 10 don't move around on me. Funnily enough, the Liberty 4 NC feel a smidge loose but I think it's more because the tips are thin so the TWS actually can move even though the tips are secure. They actually flip inside out almost every time I remove them from my ears.
The Liberty 4 NC are not perfect as my comments indicate. But their issues are small and value they present is huge.
