scubaphish
Interesting that they don’t even mention the UV gizmo in the videoShame that the case looks a bit too big/flashy :/
I’m listening to a Pink Floyd DSD album that’s 11.2 MbpsYou know that CD audio is well above 1,000kbps. Hence 990kbps can not be bit for bit. LDAC is a lossy codec.
feature, battery life, size, all seems to fit my needs.. interesting!
Ordered them today. We'll see how they sound. PM if you want a code for $20off
These look very interesting, indeed. Like the design, like the impressions so far. Hopefully they'll lean toward an MSR7B style of tuning, rather than the usual mid-bass bloat one generally finds in wireless buds.
final ze3000 should be worth a look at.So I have $75 of Amazone gift money available. Based on Amazon only availability what would be a worthwhile TWS to consider. Budget limitation of $150Cad. I can get the Soundcore L3P for $150 so that one I am thinking of. Is there any other good choice for that price range or lower?
I love my Linkbuds S and they are my daily driver. I am wanting something that will have amazing 3D imaging or a more dynamic bigger sound as an alternative. It would be nice to have an app and things like ANC but since the Linkbuds do all that these feature are less important.
To help rule out some usual suspects I already own or have owned:
In Between Pro
Galaxy Buds Pro
Sennheiser CX400
Sony WF-1000XM3
Jabra Elite 3 and 7
Might be some more but can't think of them off the top of my head.
Not willing to spring the big bucks on the new Galaxy Buds 2 Pro, would love to try the WF-1000XM4 just to see if my thoughts on them are accurate or not but can't afford that high a price tag just to satisfy curiosity.
I looked to see if I could get the Tinbud 3 but not available through Amazon Canada yet .
How about LG FP9 I can get one through the outlets store for under $150? NVM apparently has major cosmetic damage. So a no go for me...
Just an FYI on battery life… from Soundcore FAQ: 8hrs with ANC and only 5 hours with talk+ANC.Ordered them today. We'll see how they sound. PM if you want a code for $20off
Based on my experience with TWS they all drain battery quite a bit when using them for calls as opposed to just playing music.Just an FYI on battery life… from Soundcore FAQ: 8hrs with ANC and only 5 hours with talk+ANC.
Also, is the A40 Soundcore’s equivalent to the 1More Evo but for less money?
Full info:
Normal Mode: Up to 10 hours on a single charge of the earbuds. 50 hours with the charging case.
Noise Cancelling Mode: Up to 8 hours on a single charge of the earbuds. 40 hours with the charging case.
Transparency Mode: Up to 8 hours on a single charge of the earbuds. 40 hours with the charging case.
Call: Up to 6 hours in Normal mode. 5 hours in ANC mode.
Note: Battery playtime is obtained from testing in the Anker laboratory using the earbuds' default settings, in normal mode, and 50% volume. The actual playtime may vary by volume, audio source, environmental interference, usage, etc.
