Hello all!
Long time lurker, but apparently a first-time poster (I could've sworn I had created an account in the past....) anyway... I waited explicitly for the Senn MTW as my launch into the world of expensive true wireless earbuds. I did buy a cheap pair from amazon to be sure that I liked using them, but then I waited for the MTW as I know I am very picky when it comes to sound quality (aptxHD, LL, usb c - what's not to like?).
Received them from my Amazon order on 12/17. I've been listening to them pretty much non-stop for about a week. I really like them, but there are a few things I am struggling with:
#1 - When the earbuds are in the case and the case loses charge, the earbuds seem to think that they are being called to action and so they connect to my phone (stealing my audio stream) and they have to be manually disconnected by pressing and holding both (or you can plug the chase in - giving it power and letting it tell the buds that they are charging again). I have found the earbuds dead after they started playing in the case overnight. I really hope they can fix this with a firmware update or a case fix.
#2 - Max volume - I am a bit of a basshead and probably listen to things at unhealthy volumes at times - I don't love that my standard volume with these is 1 bump away from maximum. It hasn't been an issue, but I assume it's not great for my battery life.
#3 - Sound - I like the sound. A lot. But... even though I like a lot of bass - the overall sennheiser U or V sound is a little off for me. I also like to have more of a sense of atmosphere and a large enough soundstage to distinguish subtleties in the bass.
#4 - Calls - I didn't expect that this would matter to me as much as it does. I have at least one person who hates talking to me when I have them on - claiming I sound distant and a little distorted (even when I'm sitting in my living room). Others have not complained, but I have not been reading positive things about the microphone for calls since.
Finally, I did buy the Comply True Wireless, one size fits all, tips and I do like them on the MTW - it actually makes the sounds a little more pleasant for me, and the fit is solid. The one difference is that I take the added step of rolling them before insertion which is a little slower. I'd recommend the tips to anyone who likes comply or who finds they're between sizes in the regular tips.
So, I decided I'm going to try the Westone Bluetooth 5.0 V2 cable:
https://www.westone.com/store/music/index.php/bluetooth-v2-cable
I have my Fender FXA2 iems just sitting around not being used, so I thought I'd give this a go - given there are some promising reviews for this cable. I think I am going to return the MTW, but I'm waiting a day or two to decide.
Can't wait to see what's next in this space!
